Re: 3D printed parts
North Woods /
> Joel P Wrote:
> Oh and temps are around 250c but that can vary, Depends on
> manufacturer. Also having an enclosed print helps tremendously with
> warp with the nylon side. Even a cardboard box cover can help.
Head to local hardware store with a $20 and grab a sheet of FOAMULAR (Those big pink foam 4x8 insulation sheets) I lined a couple of server racks I had picked up cheap and it works great. I had to run some ducting for fume control with ABS but it's worked perfectly with the upgraded heatbeds.
And if you're cheap you can usually find scraps of that rigid foam board insulation all over that people are chucking out.
