Re: UPS Magnum Refurbishment
Probably Fred /
> ***Vanilla Thunder*** Wrote:
> Puck replacement takes like 30 minutes at most, not a whole afternoon.
Yeah if you bang the lock washer against the crank, use a piston stop impact driver, don’t talk nothing, destroying bearings on crank end and possibly bending the crank end Instead of crimping it with pliers, ya don't re shim, don’t inspect everything! Including Bearings and or reshim and blueprint everything in tranny including where the roller/thrust plate shimming,
ya don’t smooth burs on mating surfaces so you don’t have leaks on clutch cover gasket,
It takes basically 30 minutes to drain oil, remove spring to kickstand and clean Engine mating surfaces, I can’t stand people who I like you who lie about time!
I wouldn’t buy a bike from you if my life depended on it from you, if you believe 30 minutes (not counting your shady history) but from what you say is true it be like a $20 service charge to do a shift dampener change, Including road test everything came back perfect like what you claim!
I blueprint a Za50 build so it lasts for years with factory manual and factory shimming tools do you? I would never do all that work for 20$ (edited)
  UPS Magnum RefurbishmentTopic by: john cervini john cervini 11/11/19 01:30PM
  Re: UPS Magnum RefurbishmentRe: Moped Lar Moped Lar 11/11/19 02:28PM
  Re: UPS Magnum RefurbishmentRe: Dirty30 Dillon Dirty30 Dillon 11/11/19 04:29PM
  Re: UPS Magnum RefurbishmentRe: Red Foreman Red Foreman 11/11/19 02:50PM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 11/11/19 03:11PM
  Re: UPS Magnum RefurbishmentRe: live ɘvil live ɘvil 11/11/19 03:19PM
  Re: UPS Magnum RefurbishmentRe: glue baby glue baby 11/11/19 04:28PM
  Re: UPS Magnum RefurbishmentRe: Kim Jong illest Kim Jong illest 11/11/19 04:51PM
  Re: UPS Magnum RefurbishmentRe: live ɘvil live ɘvil 11/11/19 05:20PM
  Re: UPS Magnum RefurbishmentRe: Probably Fred Probably Fred 11/11/19 05:27PM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 11/12/19 12:20PM
  Re: UPS Magnum RefurbishmentRe: Red Foreman Red Foreman 11/12/19 03:13PM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 11/13/19 06:10AM
  Re: UPS Magnum RefurbishmentRe: Stephen Keller Stephen Keller 11/16/19 11:50AM
  Re: UPS Magnum RefurbishmentRe: Red Foreman Red Foreman 11/13/19 08:25AM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 11/13/19 12:00PM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 11/16/19 05:17AM
  Re: UPS Magnum RefurbishmentRe: Moped Lar Moped Lar 11/16/19 06:03AM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 11/16/19 06:22AM
  Re: UPS Magnum RefurbishmentRe: Jansen Hanzer Jansen Hanzer 11/16/19 07:40AM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 11/16/19 09:32AM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 11/16/19 10:09AM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 11/30/19 11:32AM
  Re: UPS Magnum RefurbishmentRe: Seth B Seth B 11/30/19 12:15PM
  Re: UPS Magnum RefurbishmentRe: Red Foreman Red Foreman 11/30/19 05:02PM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 12/01/19 09:48AM
  Re: UPS Magnum RefurbishmentRe: Moped Lar Moped Lar 12/01/19 10:24AM
  Re: UPS Magnum RefurbishmentRe: Rebel Moby Rebel Moby 12/01/19 09:50AM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 12/01/19 12:38PM
  Re: UPS Magnum RefurbishmentRe: Kenneth Hill Kenneth Hill 12/01/19 04:46PM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 12/19/19 02:48PM
  Re: UPS Magnum RefurbishmentRe: ID OD ID OD 12/19/19 04:31PM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 12/21/19 08:46AM
  Re: UPS Magnum RefurbishmentRe: Stephen Keller Stephen Keller 01/04/20 02:04PM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 12/24/19 11:08AM
  Re: UPS Magnum RefurbishmentRe: Daniel '' Daniel '' 01/04/20 03:04PM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 01/04/20 01:41PM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 01/05/20 07:58AM
  Re: UPS Magnum RefurbishmentRe: Kenneth Hill Kenneth Hill 01/05/20 09:34AM
  Re: UPS Magnum RefurbishmentRe: scuitar rex scuitar rex 01/05/20 09:46AM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 01/05/20 12:12PM
  Re: UPS Magnum RefurbishmentRe: Kenneth Hill Kenneth Hill 01/05/20 09:16PM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 04/24/20 10:21AM
  Re: UPS Magnum RefurbishmentRe: Stephen Keller Stephen Keller 04/24/20 01:50PM
  Re: UPS Magnum RefurbishmentRe: john cervini john cervini 04/26/20 12:37PM
  Re: UPS Magnum RefurbishmentRe: ◕ ‿ ◕ ◕ ‿ ◕ 04/26/20 12:47PM
