> ***Vanilla Thunder*** Wrote:
> Puck replacement takes like 30 minutes at most, not a whole afternoon.
Yeah if you bang the lock washer against the crank, use a piston stop impact driver, don’t talk nothing, destroying bearings on crank end and possibly bending the crank end Instead of crimping it with pliers, ya don't re shim, don’t inspect everything! Including Bearings and or reshim and blueprint everything in tranny including where the roller/thrust plate shimming,
ya don’t smooth burs on mating surfaces so you don’t have leaks on clutch cover gasket,
It takes basically 30 minutes to drain oil, remove spring to kickstand and clean Engine mating surfaces, I can’t stand people who I like you who lie about time!
I wouldn’t buy a bike from you if my life depended on it from you, if you believe 30 minutes (not counting your shady history) but from what you say is true it be like a $20 service charge to do a shift dampener change, Including road test everything came back perfect like what you claim!
I blueprint a Za50 build so it lasts for years with factory manual and factory shimming tools do you? I would never do all that work for 20$ (edited)
