> Guthrie Mass Wrote:
> > Overpriced Parts Wrote:
> > > Seth B Wrote:
> > > The first symptom of bad shift pucks/dampers is missing teeth from
> > your
> > > gears. They are just nylon discs that are forty years old, and they
> > are
> > > always bad unless they have been replaced. They are old and crumbly,
> > and
> > > when they crumble away, your tranny slams metal on metal when it
> > shifts,
> > > shredding teeth off the gears. It might do it in five miles or five
> > > hundred, but it will happen. Read the tutorial on changing them in
> the
> > > wiki. It will give you a good idea if it is a job you’re comfortable
> > > taking on.
> > Not exactly true, if bike left stock rarely will the gears be shredded
> > as soon as you use it the first generation za50s had no shift
> dampeners
> > at all, if bike was clean and taken care of with the correct tranny
> oil
> > changes and if it shifts real smooth and quiet you could ride it and
> be
> > OK but if you hear it banging into second do not run until
> > fixed/changed,
> > Blip shifting/short shifting with throttle can lessen gear damage even
> > if shift dampeners are completely gone,
> > I have a few 40 year old za50 bikes that never been opened, run great
> > and shift smooth but they are clean Great condition bikes unlike the
> one
> > you’re buying,
> > Performance builds any kind definitely need to be addressed but
> there’s
> > nothing wrong with getting a bike running ok first and listening to it
> > because it may need more than just shift dampeners it could need
> > bearings too.
> Could you explain a little more about shifting on ZA50’s? If it’s an
> automatic, around what RPM does it engage 2nd gear? Sorry if this is a
> dumb question, I’ve never ridden a multiple speed automatic bike before.
I haven't ridden a stock ZA in a long time, but if I recall correctly it's around like 4.5k?
