1977 Lazer Sport 50 Top Speed
Anyone have a stock 77 lazer 50 with or a moped in general with minarelli v1 .. dellorto sha 14 -12 carb.. max i seem to hit is 20mph on flat road.. looking to see if i can get it to at least go 30ish
Re: 1977 Lazer Sport 50 Top Speed
Benjamin The Wandering Pacer /
Whats your jetting? Intake size? gearing? stock pipe? need details.
jeff forty /
ill have to check.. its all stock though picked this up and it had been sitting prob since the 80's 104 miles on it
bike should do 30mph flat. early round head minarelli v1. clean the pipe first, carb should be sha 14.12, main jet 52. make sure filter in the carb for both air and fuel is clean . the bike runs bad if the air filter is not in there and both tuning tubes in the air box
jeff forty /
Only thing i have not checked is the exhaust ill take it off see if maybe some mouse crap in there.. thanks
Jeffrey Strichart /
Take the stock air cleaner off. I bought a Magnum back when they first came out and it four stroked at 20 mph and would not go any faster. I took the air cleaner off and hit 30 with no more four stroking.
Do a quick check. Pop the gas cap. Take it for a ride and see if that helps your speed. It will rule out a cap venting problem.
Tri-ped Dave O.D.B. /
They did produce some 20mph restricted models to comply with NY C class. Pop off the carb and see if you have a plugged small diameter intake They out there
