I'm thinking about buying a 1996-2003 Step Thru Tomos/Targa.
Wanting a '96, or later, due to carb placement, bigger brakes, A35 engine, etc.
I know to be sure and inspect the inside of the gas tank, the tires for tread/dry rot, hoses and cables,......but what are some other things that need to be periodically changed on that particular moped that I should ask if it has been done...(Or deduct money from the selling price if no proof of bring done)?
And not just regular maintenance...but anything to check on that model?
Forks?
Chains? Belts?
Carb work?
Tires/tubes?
Some are oil injection and some models are still pre-mix.
Is one preferred over the other?
Is the difference all just a convenience factor?
Is the oil injection reliable to always inject oil?
I am looking to find a nice one in the $400-$500 range. Less if it needs some things. (edited)
