1 wire ac to dc led solution
el pollo /
this is a post the internet does not want you to read.
there are 2 types of people who spam. owners of brands and resellers of the brands I kill. my posts always get trolled. do you think mr trailtech or mr superbright or anyone else selling here wants you to read any of this. here is where you can post your modern led solution and cost. thats the beauty of this post. its either put up or shut up. but this time you will know what type is up. it will be obvious who is a troll. they will have smart ass answers and no pic, no cost. there is as much nonsense here as there are 70mph moped threads.
this post is only about 3 things, cost, wiring diagram or explanation of how its wired and a pic of your working lights at idle, anything else is trolling.wiring solutions have to run at lease one season without blowing bulbs.
this is a solution for 1 ac wire coming out of the stator. it will work perfectly with the headlight stator. it is one solution and not the only solution. cost; rectifier kbpc5010 $1, hyperflash led flasher $1, ac regulator $9(yamaha blaster 12v), 2x red cob led's $1.50 2x yellow cob signal led's $1.50 headlight that takes modern bulbs with integrated front turn signals $12.50, led headlight 800 lumen $1.40. 63v22,00uf cap $3. current draw 10w. total cost $27.90.
you can raise the voltage of the regulator .7v if you wire a diode into the negative termainal. this will cancell out the .7v loss across the recitfier
