Re: 70cc airsal Puch maxi Wont work...
Probably Fred /
Don’t run stock type non chamber exhaust or stock air box and make sure arrow on piston is pointed down, run metal mesh filter with circuit or estroil type exhaust 78-80 with 217 atomizer/needle jet jet in real 15mm bing not junk clone,
Don’t fiddle with timing or your magneto read this first :
https://www.mopedarmy.com/wiki/Puch_timing
You should be at 45-50mph not kmph,if you’re not you’re doing something wrong,
