This creature is a Batavus frame with a puch Front-end. Not sure yet on what power plant. Im trying to go with a Peugeot 103 subframe set up. I know treats sells a subframe but I’m lost after that.Down the rabbit hole I go
If you just bolt a Pug subframe into the VA frame subframe hole, it will be unrideable-y long
I decided to go in a way different direction.I had this Minarelli vertical sitting around so yea. Should be pretty funnyTalk about long!
