Re: Mobylette 50V throttle and cables
Rebel Moby /
If there is any resistance to puling in the cable then it needs to be replaced, should be super smooth to pull and return to rest position by itself.
Depends on the reglage of the Gurtner carb, it is stamped on the fuel bowl or on the flat metal plate above the fuel bowl.
AR2-12 reg 705
AR2-12 reg 729
