Re: Wiring questions (puch e50)
Nick Haber /
> el pollo Wrote:
> another ma asshole. why don't you post diagrams, explain to the group
> all the other ways of wiring other that floating ground, full and half
> wave. there aren't any and you are a douche.
Okay, I mainly work on radar systems and antenna range automation but I'll take a stab.
Floating ground: first picture, see how the ground is there on the right side (after the amplifier) but not on the left? On the left, the battery has a floating ground. It's not directly connected to earth but the battery still provides the same voltage (e.g. 6V). The negative terminal may not be exactly 0V, but that doesn't necessarily matter since the voltage differential into the amplifier will always be 6V.
Half wave rectifier (picture 2): You have AC but you want DC so you cut off the negative portion of the AC curve to give a pulsated DC signal. Controlling the duty cycle (time pulse is off vs time pulse is on) and amplitude of the signal will yield you different average voltage values and therefore different DC values.
Full wave rectifier (pic 3): Like a half wave but uses diodes to make every pulse positive. This gives you twice the range of the half wave (e.g. you can set the voltage to anywhere inbetween 12v to -12v instead of 6v to -6v with a half wave). Of course, the current applied will be halved since you're increasing the voltage by a factor of two. I've never converted a bike to 12v, so I wasn't going to chime in. But if you put on the 12 volt coil and replace the (I assume half wave) rectifier with a full wave you should be good to go.
To El Pollo, I never said that the way to do it wouldn't involve using rectifiers, I said the way you type makes whatever you're trying to say extremely confusing for most.
  Wiring questions (puch e50)Topic by: Guthrie Mass Guthrie Mass 10/21/19 10:15PM
  Re: Wiring questions (puch e50)Re: Mike Boyd Mike Boyd 10/21/19 11:19PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 08:01AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 08:16AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 10:43AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:02AM
  Re: Wiring questions (puch e50)Re: Frank Bailey Frank Bailey 10/22/19 11:03AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 11:05AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 11:14AM
  Re: Wiring questions (puch e50)Re: Nick Haber Nick Haber 10/22/19 05:33PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 08:13PM
  Re: Wiring questions (puch e50)Re: Nick Haber Nick Haber 10/22/19 11:00PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/23/19 08:29AM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/23/19 12:25PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/23/19 08:39PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:20AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:09AM
  Re: Wiring questions (puch e50)Re: Frank Bailey Frank Bailey 10/22/19 11:40AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 01:02PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 01:23PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 02:17PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 01:56PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 03:30PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 03:01PM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/22/19 03:04PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 03:51PM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/22/19 03:47PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 04:13PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 05:26PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 06:22PM
  Re: Wiring questions (puch e50)Re: Jeff Parr Jeff Parr 10/22/19 05:36PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 05:56PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 06:26PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 06:36PM
  Re: Wiring questions (puch e50)Re: Overpriced Parts Overpriced Parts 10/22/19 07:02PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 07:51PM
  Re: Wiring questions (puch e50)Re: Chris Squid Chris Squid 10/22/19 08:39PM
