Re: Wiring questions (puch e50)
Guthrie Mass /
> el pollo Wrote:
> sorry I do this in my head.
> E=IxR E is the voltage. R is unchanged.
> 6=IxR
> double I with a bulb that has twice the current drain then the voltage
> gets lowered not raised.
What? I'm afraid I'm not following what you're saying. 12V DC that can supply 3.5-4~ amps is really what I'm worried about. According to treats, not only is that coil a higher voltage, it also can supply more current. That's the main takeaway. I guess technically the voltage is arbitrary if I was running everything off AC, but in the wave rectification, there is a current limitation, as that power has to come from somewhere. So a 25W coil running at 12V will be able to output less power than a 50W coil running at 12V. I don't see where Ohms law even comes into play here. The specifics of the power draw are not my main concern right now. I can always find lower-power lights.
> el pollo Wrote:
> no one calls moving the ground from the frame to the rectifier floating.
> ma is retarded you can not float a stator. it is idiotic.
> this is called running full wave. in this case you double the stator
> output by moving the ground off the frame.
> trouble is this requires removing the flywheel and running a wire.
> that's asking a lot from someone who is not able to test the thing.
> even if you run full wave that tap to the taillight is n/c
> use that link you posted. that guy has some advanced schooling like me.
> we talk the same language.
Avoid slurs please, advanced schooling doesn't shine through a fog of crude language. I'm not able to test the thing because I don't have a moped, thought I made that clear at the beginning, my apologies if I didn't. I'm just thinking ahead and considering how I would go about modifying something in the future that doesn't support everything that I want to do with it. The AC ground doesn't really matter to me because it won't be shared with the DC ground, nor any of the other DC wiring. All the stock AC ignition stuff will stay the same, but every other auxiliary feature will run off of DC. (edited)
  Wiring questions (puch e50)Topic by: Guthrie Mass Guthrie Mass 10/21/19 10:15PM
  Re: Wiring questions (puch e50)Re: Mike Boyd Mike Boyd 10/21/19 11:19PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 08:01AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 08:16AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 10:43AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:02AM
  Re: Wiring questions (puch e50)Re: Frank Bailey Frank Bailey 10/22/19 11:03AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 11:05AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 11:14AM
  Re: Wiring questions (puch e50)Re: Nick Haber Nick Haber 10/22/19 05:33PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 08:13PM
  Re: Wiring questions (puch e50)Re: Nick Haber Nick Haber 10/22/19 11:00PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/23/19 08:29AM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/23/19 12:25PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/23/19 08:39PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:20AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:09AM
  Re: Wiring questions (puch e50)Re: Frank Bailey Frank Bailey 10/22/19 11:40AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 01:02PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 01:23PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 02:17PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 01:56PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 03:30PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 03:01PM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/22/19 03:04PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 03:51PM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/22/19 03:47PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 04:13PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 05:26PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 06:22PM
  Re: Wiring questions (puch e50)Re: Jeff Parr Jeff Parr 10/22/19 05:36PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 05:56PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 06:26PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 06:36PM
  Re: Wiring questions (puch e50)Re: Overpriced Parts Overpriced Parts 10/22/19 07:02PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 07:51PM
  Re: Wiring questions (puch e50)Re: Chris Squid Chris Squid 10/22/19 08:39PM
