Re: Wiring questions (puch e50)
Frank Bailey /
Gupperino, I used a regulator/rectifier similar to this one. https://www.ebay.com/itm/4-Wires-Voltage-Regulator-Rectifier-ATV-GY6-50-150-Scooter-Moped-JCL-NST-TAOTAO/223707047329?epid=1739699470&hash=item3415faa5a1:g:MHMAAOSwXOVaZuvE
Mine is on a Minarelli V1, similar lighting coil. I detached the lighting coils ground and ran a wire from it out. Some call this floating the ground. Then connected these AC wires to the yellow and pink wires on the regulator. Now you can just use the red and green as your output and even use chassis ground. True it's still a 6-volt coil but I switched to LCD's and there is enough current even at idle to fire the headlight with minimal flicker. A capacitor or even a battery could be added but for keeping it inexpensive and simple this works. Use the search function, there are many here who have done this and similar variations. Go for it!
I left the stoplight circuit alone and simply added an LED tail light. I snuck a diode in just for some cheap insurance. (edited)
  Wiring questions (puch e50)Topic by: Guthrie Mass Guthrie Mass 10/21/19 10:15PM
  Re: Wiring questions (puch e50)Re: Mike Boyd Mike Boyd 10/21/19 11:19PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 08:01AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 08:16AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 10:43AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:02AM
  Re: Wiring questions (puch e50)Re: Frank Bailey Frank Bailey 10/22/19 11:03AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 11:05AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 11:14AM
  Re: Wiring questions (puch e50)Re: Nick Haber Nick Haber 10/22/19 05:33PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 08:13PM
  Re: Wiring questions (puch e50)Re: Nick Haber Nick Haber 10/22/19 11:00PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/23/19 08:29AM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/23/19 12:25PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/23/19 08:39PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:20AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:09AM
  Re: Wiring questions (puch e50)Re: Frank Bailey Frank Bailey 10/22/19 11:40AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 01:02PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 01:23PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 02:17PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 01:56PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 03:30PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 03:01PM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/22/19 03:04PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 03:51PM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/22/19 03:47PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 04:13PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 05:26PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 06:22PM
  Re: Wiring questions (puch e50)Re: Jeff Parr Jeff Parr 10/22/19 05:36PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 05:56PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 06:26PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 06:36PM
  Re: Wiring questions (puch e50)Re: Overpriced Parts Overpriced Parts 10/22/19 07:02PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 07:51PM
  Re: Wiring questions (puch e50)Re: Chris Squid Chris Squid 10/22/19 08:39PM
