Re: Wiring questions (puch e50)
Guthrie Mass /
> el pollo Wrote:
> more moped army nonsense. you cant float a stator period. what is wrong
> with the people here. the only thing you can do with a stator is change
> where its grounded.
> 6 to 12 what's wrong with using ohms law to do it. change in load will
> change the voltage. what you need is modern bulbs, not a different
> stator.
> the lighting coil has nothing to do with ignition. it has its own
> dedicated stator.
> that crappy diagram does not show much. seems to be a recurrent problem
> here. you need to test the stator and see how the thing is wired
> yourself. once you know how the stator is wired then you can order the
> right type of modern r/r.
> one hint. the tail light runs off a tap in the stator. it is not used in
> your conversion.
Appreciate your response, but would love a little friendlier of a tone :).
Anyhoo, yes, generally speaking the ground would be on the frame and can’t be floated, but because I’d run DC separately into each component it doesn’t really matter.
The 12V coil off treats doesn’t have its wattage listed, but according to a review one tap can power a 55W halogen + more. So because (I believe) the the stock coil is just generally weaker, it doesn’t make sense for me to step it up and loose some current carrying abilities.
I have considered just trying to find super efficient bulbs, which I’ll have to do anyway, but I want to power a LOT of stuff, and I want a stable supply to all of them (horn, LED’s, turn signals, etc).
  Wiring questions (puch e50)Topic by: Guthrie Mass Guthrie Mass 10/21/19 10:15PM
  Re: Wiring questions (puch e50)Re: Mike Boyd Mike Boyd 10/21/19 11:19PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 08:01AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 08:16AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 10:43AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:02AM
  Re: Wiring questions (puch e50)Re: Frank Bailey Frank Bailey 10/22/19 11:03AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 11:05AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 11:14AM
  Re: Wiring questions (puch e50)Re: Nick Haber Nick Haber 10/22/19 05:33PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 08:13PM
  Re: Wiring questions (puch e50)Re: Nick Haber Nick Haber 10/22/19 11:00PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/23/19 08:29AM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/23/19 12:25PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/23/19 08:39PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:20AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:09AM
  Re: Wiring questions (puch e50)Re: Frank Bailey Frank Bailey 10/22/19 11:40AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 01:02PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 01:23PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 02:17PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 01:56PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 03:30PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 03:01PM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/22/19 03:04PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 03:51PM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/22/19 03:47PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 04:13PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 05:26PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 06:22PM
  Re: Wiring questions (puch e50)Re: Jeff Parr Jeff Parr 10/22/19 05:36PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 05:56PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 06:26PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 06:36PM
  Re: Wiring questions (puch e50)Re: Overpriced Parts Overpriced Parts 10/22/19 07:02PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 07:51PM
  Re: Wiring questions (puch e50)Re: Chris Squid Chris Squid 10/22/19 08:39PM
