Wiring questions (puch e50)
Guthrie Mass /
I'm wondering this in general, but for this post I'll ask about the E50 from Puch, as that's the wiring diagram I'm looking at (https://www.mopedarmy.com/w/images/b/bb/Stock_puch_wiring_diagram.jpg).
I drew it out as a modified version, and essentially I'd be replacing the stock 6V lighting coil with a 12V lighting coil, and off of that I'd run it directly into a rectifier and then a 14~ish volt regulator for charging a 12V battery (I might need a dedicated charging circuit between here though), and then off the battery I'd have one more 12V reg going to all my lights, a new horn, signals, etc.
So my questions are as follows:
How does one go about replacing a lighting coil? I know that's vague but in this example a puch e50 diagram is pretty simple, but the wires coming off the generator are unclear. It's not really revealed which coil even is the lighting coil.
Would I need some sort of dedicated battery charging circuit after a 12V reg/rectifier? If so, can you link me something?
Thanks!
EDIT:
On treats, https://www.treatland.tv/puch-12-volt-light-coil-2-0-improved-version-p/puch-light-coil.htm this coil seems like a good point of reference. The review says that only one of the rails really matters, as the headlight cable will power everything sufficiently. I just need it to get fed into a couple of components and then a battery. So is it safe to assume that this would get wired up yellow wire (12V AC) to the positive input of a rectifier/regulator, and then it would share an AC ground with the ignition coil (meaning the brown wire on the diagram would go into the negative input of the rectifier/regulator)? (edited)
  Wiring questions (puch e50)Topic by: Guthrie Mass Guthrie Mass 10/21/19 10:15PM
  Re: Wiring questions (puch e50)Re: Mike Boyd Mike Boyd 10/21/19 11:19PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 08:01AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 08:16AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 10:43AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:02AM
  Re: Wiring questions (puch e50)Re: Frank Bailey Frank Bailey 10/22/19 11:03AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 11:05AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 11:14AM
  Re: Wiring questions (puch e50)Re: Nick Haber Nick Haber 10/22/19 05:33PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 08:13PM
  Re: Wiring questions (puch e50)Re: Nick Haber Nick Haber 10/22/19 11:00PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/23/19 08:29AM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/23/19 12:25PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/23/19 08:39PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:20AM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 11:09AM
  Re: Wiring questions (puch e50)Re: Frank Bailey Frank Bailey 10/22/19 11:40AM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 01:02PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 01:23PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 02:17PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 01:56PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 03:30PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 03:01PM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/22/19 03:04PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 03:51PM
  Re: Wiring questions (puch e50)Re: Dirty30 Dillon Dirty30 Dillon 10/22/19 03:47PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 04:13PM
  Re: Wiring questions (puch e50)Re: el pollo el pollo 10/22/19 05:26PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 06:22PM
  Re: Wiring questions (puch e50)Re: Jeff Parr Jeff Parr 10/22/19 05:36PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 05:56PM
  Re: Wiring questions (puch e50)Re: Graham Motzing Graham Motzing 10/22/19 06:26PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 06:36PM
  Re: Wiring questions (puch e50)Re: Overpriced Parts Overpriced Parts 10/22/19 07:02PM
  Re: Wiring questions (puch e50)Re: Guthrie Mass Guthrie Mass 10/22/19 07:51PM
  Re: Wiring questions (puch e50)Re: Chris Squid Chris Squid 10/22/19 08:39PM
