Re: Hobbits or Maxis? i'm torn between 2 lovers.
Rebel Moby /
Not all mopeds are monocoque, but the ones that have the tank integral to the frame you do need to be wary if there is signs of fuel leaking, tin worm on the tank, rust or cracks at the base of the tanks. Cracks without substantial rust can be easily welded, sometimes holes can be repaired and a upper stress bar added for insurance, Tanks often rust from the inside out from water in the fuel, so check carefully if there are a few rust bubbles, it could be more than it appears.
> Piston Broke Wrote:
> I see that I am considering 2 very good models of mopeds.
> I am leaning towards the Hobbit.
> Turn signals
> The CVT for hills
> The amazing performance potential
> Thanks everyone!
> I missed Tomos earlier!
> Thank you and yes, i will keep away from rust, both inside the tank and
> out.
> Hello Jeffrey, showing your age ''era'' there right along with me!
> Thanks Thomas, Puch guy I see with your Maxi Luxe, nice I'm sure. I
> appreciate it.
> Thanks Nick, now I have to decide if i want my moped's carb is to be the
> hard to clean Keihin or a Bing that leaks?
> Lol
> Rebel, thanks for taking time to respond, with all that info.
> There's a word ya don't hear very often....monocoque.
> All one piece hollow frame?
> So the Puch is monocoque but not the Hobbit, correct?
> Or are all mopeds monocoque?
> Will, thanks also for taking the time to chime in with your opinions.
> Graham, great explanations and comparisons with lots of super info!
> Much appreciate your time and knowledge.
> Thanks again and I hope I didn't miss anyone.
  Hobbits or Maxis? i'm torn between 2 lovers.Topic by: Piston Broke Piston Broke 10/21/19 07:28PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: P D P D 10/21/19 08:42PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/21/19 08:48PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/21/19 08:55PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: * * * * 10/21/19 09:32PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Rex Sheler Rex Sheler 10/21/19 09:38PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Bas Autowas Bas Autowas 10/21/19 10:01PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Potr zebie Potr zebie 10/22/19 10:50AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: - schmiddy - schmiddy 10/21/19 10:03PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/21/19 10:52PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Stephen Keller Stephen Keller 10/22/19 05:11AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Tomos A35 Tomos A35 10/22/19 06:18AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Chris Szuba Chris Szuba 10/22/19 06:37AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Bad Cadillac™ Bad Cadillac™ 10/22/19 06:45AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: ***Kim Jong illest*** ***Kim Jong illest*** 10/22/19 07:44AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Dave Steele Dave Steele 10/22/19 09:54AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Graham Motzing Graham Motzing 10/22/19 02:12PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 08:39AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Jeffrey Strichart Jeffrey Strichart 10/22/19 10:21AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Thomas Peffer Thomas Peffer 10/22/19 10:23AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/22/19 10:29AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Rebel Moby Rebel Moby 10/22/19 10:45AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Born to be WillD Born to be WillD 10/22/19 11:03AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 04:12PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Rebel Moby Rebel Moby 10/23/19 09:53AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 04:15PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Alex Gween Blastard Alex Gween Blastard 10/22/19 07:31PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Avery M. Avery M. 10/22/19 08:07PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/22/19 10:21PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: ***Kim Jong illest*** ***Kim Jong illest*** 10/22/19 09:25PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 09:31PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 09:45PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: pat splat pat splat 10/23/19 08:30AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/23/19 03:52PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/23/19 09:46AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/23/19 03:54PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/23/19 04:13PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/23/19 05:41PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Trent Anderson Trent Anderson 10/23/19 01:56PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Overpriced Parts Overpriced Parts 10/23/19 04:50PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Juan Grandé Juan Grandé 10/23/19 04:05PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Trent Anderson Trent Anderson 10/23/19 10:17PM
