Re: Hobbits or Maxis? i'm torn between 2 lovers.
Graham Motzing /
> ***Vanilla Thunder*** Wrote:
> some opinions:
the big difference is that puchs are a more simplistic older technology (50's tech) solution, the hondas are a more modern (late 70's, really 80's tech)
i've owned both but i always sell the hondas off, they are fast, reliable, super easy to work on (don't believe the hype about the carbs, they are easy peasy) smooth and comfortable, that said i don't enjoy working on them as much and they bore me.
compared to cars, the puch maxi is the vw beetle of mopeds, the honda is a very honda-like early 80's civic perhaps. They are both pretty similar size, weight, even performance but the honda accomplishes everything using more modern design, its still not complex or hard to work on, but using modern technology things tend to be slightly more convoluted, but better in many ways.
depending on how much you want to spend, you'll probably just end up owning whatever comes along first within your price range, most people around here find our mopeds however they pop up and learn to love them as we fix them up.
i'm always a fan of steering people towards the puch (e50), tomos, minarelli v1 as first mopeds because they tend to be the most forgiving. any one of those three will run just about no matter what. i've had a few hobbits over the years that were just total dickbags and fought me all the way up until a full rebuild
  Hobbits or Maxis? i'm torn between 2 lovers.Topic by: Piston Broke Piston Broke 10/21/19 07:28PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: P D P D 10/21/19 08:42PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/21/19 08:48PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/21/19 08:55PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Rocco Taco Rocco Taco 10/21/19 09:32PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Rex Sheler Rex Sheler 10/21/19 09:38PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Bas Autowas Bas Autowas 10/21/19 10:01PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Potr zebie Potr zebie 10/22/19 10:50AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: - schmiddy - schmiddy 10/21/19 10:03PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/21/19 10:52PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Stephen Keller Stephen Keller 10/22/19 05:11AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Tomos A35 Tomos A35 10/22/19 06:18AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Chris Szuba Chris Szuba 10/22/19 06:37AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Bad Cadillac™ Bad Cadillac™ 10/22/19 06:45AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: ***Kim Jong illest*** ***Kim Jong illest*** 10/22/19 07:44AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Dave Steele Dave Steele 10/22/19 09:54AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Graham Motzing Graham Motzing 10/22/19 02:12PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 08:39AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Jeffrey Strichart Jeffrey Strichart 10/22/19 10:21AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Thomas Peffer Thomas Peffer 10/22/19 10:23AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/22/19 10:29AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Rebel Moby Rebel Moby 10/22/19 10:45AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Born to be WillD Born to be WillD 10/22/19 11:03AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 04:12PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Rebel Moby Rebel Moby 10/23/19 09:53AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 04:15PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Alex Gween Blastard Alex Gween Blastard 10/22/19 07:31PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Avery M. Avery M. 10/22/19 08:07PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/22/19 10:21PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: ***Kim Jong illest*** ***Kim Jong illest*** 10/22/19 09:25PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 09:31PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 09:45PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: pat splat pat splat 10/23/19 08:30AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/23/19 03:52PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/23/19 09:46AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/23/19 03:54PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/23/19 04:13PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/23/19 05:41PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Trent Anderson Trent Anderson 10/23/19 01:56PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Overpriced Parts Overpriced Parts 10/23/19 04:50PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Juan Grandé Juan Grandé 10/23/19 04:05PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Trent Anderson Trent Anderson 10/23/19 10:17PM
