Re: Hobbits or Maxis? i'm torn between 2 lovers.
Rebel Moby /
I have wrenched and owned both Puch and Honda, neither are my principal choice of bikes but choice comes down to personal taste as well as other factors. So maybe my opinions are less biased as they are not my main ride(s).
Sorry Puch folks, I would suggest the Honda as the better ride and wrenchability over the Puch.
Based on some of the above comments...
Folks complain about the Honda's carb quality and placement issue, just get a different intake set up so it has a right angle and that issue is done, the quality issue is just needing to clean it properly.
If you had other Honda bikes before the wiring will be no problem because it follows the Honda Common Wiring scheme.
If properly tuned, Hondas, even after sitting long time, will start one kick to prime one to start, while standing beside the bike (and not using it as a stationary exercise bicycle). Puchs... actually will start exactly the same when in good tune. So I dont know about some of the other comments.
Monocoque bikes have an issue with frames rusting from the inside out, this pertains to all of them not just Puch. Staying on topic though, I have scrapped 3 Puch bikes from tank rust through, zero Hondas scrapped for same reason because you can just hunt down a new tank (or add a upper stress bar and substitut a small top tank).
But final choice comes down to personal taste, neither are hugely more difficult that the other, both have their own appeals.
  Hobbits or Maxis? i'm torn between 2 lovers.Topic by: Piston Broke Piston Broke 10/21/19 07:28PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: P D P D 10/21/19 08:42PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/21/19 08:48PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/21/19 08:55PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Rocco Taco Rocco Taco 10/21/19 09:32PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Rex Sheler Rex Sheler 10/21/19 09:38PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Bas Autowas Bas Autowas 10/21/19 10:01PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Potr zebie Potr zebie 10/22/19 10:50AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: - schmiddy - schmiddy 10/21/19 10:03PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/21/19 10:52PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Stephen Keller Stephen Keller 10/22/19 05:11AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Tomos A35 Tomos A35 10/22/19 06:18AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Chris Szuba Chris Szuba 10/22/19 06:37AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Bad Cadillac™ Bad Cadillac™ 10/22/19 06:45AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: ***Kim Jong Uno*** ***Kim Jong Uno*** 10/22/19 07:44AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Dave Steele Dave Steele 10/22/19 09:54AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Graham Motzing Graham Motzing 10/22/19 02:12PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 08:39AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Jeffrey Strichart Jeffrey Strichart 10/22/19 10:21AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Thomas Peffer Thomas Peffer 10/22/19 10:23AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/22/19 10:29AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Rebel Moby Rebel Moby 10/22/19 10:45AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Born to be WillD Born to be WillD 10/22/19 11:03AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 04:12PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Rebel Moby Rebel Moby 10/23/19 09:53AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 04:15PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Alex Gween Blastard Alex Gween Blastard 10/22/19 07:31PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Avery M. Avery M. 10/22/19 08:07PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/22/19 10:21PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: ***Kim Jong Uno*** ***Kim Jong Uno*** 10/22/19 09:25PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 09:31PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 09:45PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: pat splat pat splat 10/23/19 08:30AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/23/19 03:52PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/23/19 09:46AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/23/19 03:54PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/23/19 04:13PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/23/19 05:41PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Trent Anderson Trent Anderson 10/23/19 01:56PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Overpriced Parts Overpriced Parts 10/23/19 04:50PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Juan Grandé Juan Grandé 10/23/19 04:05PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Trent Anderson Trent Anderson 10/23/19 10:17PM
