Hobbits or Maxis? i'm torn between 2 lovers.
Hello everyone,
I'm David, a new guy on here. Thanks for having me!
I'm looking for my first moped, (other than a few i've owned a month or so, or... a day or so.)
Me, working on a moped?
I am fairly mechanically inclined.
I'd would say I'm a solid 7 on the 1-10 scale, so I'm actually probably more like a 6.
Maybe a 7 with a service manual and some good advice.
I'm considering a Honda Hobbit, because I've had Honda cars and motorcycles that were completely reliable,...and smooth.
After looking through lots of posts here, I'm also thinking Puch Maxi LS (with the long seat), or with the seat for 2.
For the long seat, it seems I'm looking for the Puch Maxi Sport.
I'm considering a Puch because I see relability is great on those.
It also seems there is more available stuff for Puchs (parts bikes, or aftermarket parts).
Also, I see Puchs are easier to work on than Hobbits (for a first timer like me).
I saw somewhere, the forks aren't available for a certain Puch. I forget which one it said, but I know I don't wanna get that one.
Also, a nasty gas tank can't be replaced on the Puch like on the Hobbits (i guess).
Turn signals are a must!
So it's Hobbits 1981 and after it appears.
Not sure just yet what year Maxis have turn signals.
I looked at Myrons info on Puchs, and the Puch wiki threads on here and general Puch maxi searches.
Confusing....how an engine can be a 2-speed, but it seems like the e50 is the engine to get, due to it being a tough engine but also easier to work on than the z50.
I also see the transmission can be 1 speed or 2.
I'd think i'd want the 2 speed so the engine's rpms will drop.
Any easy explanation of the best engine and transmission combination that's best to get and how it works?
I am gonna need the 2.0 hp version, versus 1.0 or 1.5.
I only weigh about 175 but I need speed!
Can the long seat be put onto any of the Puch Maxis or do I need to get the model that comes with the long seat?
I am gonna prefer the wider front wheel and tire. I would think it would ride smoother around cracks.
With all this info,...for which model Puch Maxi should I be looking?
And,...do YOU prefer Hobbits or Puch Maxis...and why?
I'm trying to get educated so I don't get one, and find out a month later I should have gotton a different model.
All answers, tips, comments, thoughts, photos and/or ideas are both welcomed and encouraged!
Thank you
Re: Hobbits or Maxis? i'm torn between 2 lovers.
When I first started looking , I had much that same questions .
My answer was very simple : None compare to Japanese .
I bought a 1984 Suzuki FA50 with close to 5,000 miles on the clock , about 10 years ago . Gave it the once over . Replaced a couple things like tires , a coil and fenders . Adapted a tail light I had and been riding worry free since . That , until the mud daubers totally filled the exhaust outlet and had me stumped for an hour or so .
Oh , I had a major expense recently : I had to buy a new inner tube because I could not get the old one to hold air for long . That cost me a whole 10 bucks , but , I did buy the heavy duty version . (edited)
Get a hobbit. A hobbit is just all around better than a Puch. Puchs are simpler, but not by much. You talk about wanting a 2 speed, but the Hobbit's CVT will be better than any ZA50.
Both great answers.
Thanks both for taking the time.
If you wanna haul ass then buy a hobbit!
Wheelies dawg wheelies
Now if you wanna go really fast get a scooter but you didn’t hear that from me. That being said I have a few scooters that I barely even try to tune and they are way fast then any of the mopeds will ever be.
An E50 makes a great lover!
I have one Hobbit, a Maxi and 2 magnums. The puchs are all easier to tune than a hobbit when you try to make them faster than stock. Magnums are the most comfortable. If i sell a bike, it's going to be the hobbit. Get an E50 Puch.
E50 is better because I don't trust Belgians.
I disagree with the above testimonials. Both Puchs (Maxi) and Honda Hobbits are fine but both have drawbacks too.
The Maxi’s interval tank is mighty inconvenient to clean out if it’s rusty but the hobbit tank is a horrible design to do the same. Pinto/Swinger or Free Spirit have removable tanks that are super easy to maintain.
Puchs are stupid simple. There’s only a dozen or so moving parts/components in an E50 and they are probably to most reliable, durable and forgiving engines I’ve ever worked on. Parts are cheap and available everywhere. The PA engine and drive system is a far more advanced design but It never liked having to drop the engine to get to the carburetor - which you’d have to do (repeatedly) when it gets dirty, and that Kehlin carb is bloody awful.
The Honda PAII is dual variated, which is great for rapid acceleration and climbing hills. It’s a system capable of amazing performance potential. Avoid the single variated PAI though.
Hobbit electrics are a dumb, fucked up mess. Just remove the headlight lamp and take a look at the rat’s nest behind it. I could go on nit picking the Hobbit but their engine is outstanding; everything else bolted onto it is way overrated in my honest opinion.
What you said about the variator is factually incorrect. The pa50ii has a better variator ramp plate than a 50i, that's the difference. Hobbit electrical is complicated for mopeds I guess, but easy for motorcycles. My hobbit wiring is very very similar to a lot of the small displacement Hondas I own
No Maxi's have turn signals stock, a cat-eye kit can be added or make your own, but you don't need them. I would say if in good condition go with the Hobbit, I have had mine since '98, never left me, great take off and great on hills. If In poor condition opt for the Puch, easier to bring back, but inspect the fuel tank very carefully. Never had one, but if I had room for another bike Vespa is right up there.
Get them both or whatever makes u happy yolo.
Most mopeds are easy to work on u can learn alot from the wiki or just ask. Don't buy anything rusted really bad that's my only advice.
dont compare hobbits to their cars. although both great, mopeds are a different game entirely. hobbits are fantastic though, highly recommend. plus variated for hills is awesome. TLDR but some maxi's are only single speeds and you might need to peddle a little to get going
get a hobbit
get the honda hobbit habbit. dont look back
Bad Cadillac™ /
Drive both before you buy one. Then you'll know what you're starting from.
***Kim Jong illest*** /
real facts:
PUCH:
pros:
tanks are easy af to clean, and you only have to do it once, if at all.
all the parts for them are dirt cheap and practically everything is available
they are so common that even the stuff treats doesnt sell you can get online easily
great bang for buck ratio
easy for beginners
the best designed and well built moped motors ever
overall, no matter the model, the design is fantastic and rider comfort is A+
bullet proof
easy to make go fast
cons:
cant really think of any
HOBBIT:
pros:
bolt on parts add more power than they should for a moped
has potential to be insanely fast
every day more options become available for them
strong community of followers
dual variation cant be beat
cons:
pa50 I needs all of the pa50 II stuff to be worth a damn
stock carbs are garbage
simple jobs like a carb cleaning are a chore and a half
horrible tank design
fork rake is stout and less than ideal
harder to start
both are great options and IMO the honda can be made stupid fast more easily BUT the puchs are better designed and cheaper to maintain and have a much bigger community behind them. you really cant go wrong either way.
Awesome, great written responses everyone! Exactly what I was looking for.
Pros, cons, etc.
I really appreciate all you guys taking your time to respond.
Thanks PD, i agree with Japanese making good engines.
Thanks Nick, and yes i've been told good things about the CVT for hills.
I don't wanna be peddling up a hill. If I did, I'd buy a 10-speed.
I for sure knew not to get the PAI Hobbit from '78 and '79.
The PAII, 1981 with turn signals, is what I'm considering.
Rocco, thanks, I am gonna wanna haul some ass here and there!
I'd like a moped quick enough that I could wheelie, although i will keep both wheels on the ground.
Thanks Rex! Let me know when yours is for sale,...(if your Hobbit has turn signals).
I really do want turn signals.
Right on, Bas. Don't trust nobody, lol.
Schmiddy, thanks for splaining all that.
I appreciate you taking all the time to do that!
Thanks Stephen, wow you've had your Hobbit 20 years, nice.
Wow, no Maxis with factory turn signals...good to know.
Tomos, thanks, I may get both....(in time). Ride one while I tinker and tune the other.
Chris Szuba, thank you,... and I never wanna peddle. Lol
Bad Cadillac, thank you. As long as I'm not crouched over like on a Puch Magnum, or other crotch rocket style, I will be fine.
I have a busted up back, so i like like sitting upright, with high handlebars, which Hobbit and Maxis are.
As cool as they look, cafe racers unfortunately won't be comfortable for me.
Josh, thanks for taking the time to splain the pros and cons!
Awesome
Thanks everyone!
Exactly the type info I was needed!
Maxi....................*....Hobbit
Leaning toward the Hobbit....so far.
> ***Vanilla Thunder*** Wrote:
> real facts:
> PUCH:
> pros:
LOL.
Jeffrey Strichart /
Loving both of you is breaking all the rules.
Of course I'm gonna favor a Puch. Easy to work on, can be made to go fast, parts easily available to get, good following, very reliable. Make Puch Great Again!
I think 5-6 years ago Puch would be a better choice due to the aftermarket support lacking for hobbits. But that's not the case anymore. The only advantage a Puch has over a hobbit in my book is that the carb can be removed a lot easier. But once you get a system down for removing a hobbit carb it's not an issue anymore. Plus Bings suck; every non new Bing that I've had has leaked. Keihins (hobbit carbs) are good carbs, just hard to clean.
I have wrenched and owned both Puch and Honda, neither are my principal choice of bikes but choice comes down to personal taste as well as other factors. So maybe my opinions are less biased as they are not my main ride(s).
Sorry Puch folks, I would suggest the Honda as the better ride and wrenchability over the Puch.
Based on some of the above comments...
Folks complain about the Honda's carb quality and placement issue, just get a different intake set up so it has a right angle and that issue is done, the quality issue is just needing to clean it properly.
If you had other Honda bikes before the wiring will be no problem because it follows the Honda Common Wiring scheme.
If properly tuned, Hondas, even after sitting long time, will start one kick to prime one to start, while standing beside the bike (and not using it as a stationary exercise bicycle). Puchs... actually will start exactly the same when in good tune. So I dont know about some of the other comments.
Monocoque bikes have an issue with frames rusting from the inside out, this pertains to all of them not just Puch. Staying on topic though, I have scrapped 3 Puch bikes from tank rust through, zero Hondas scrapped for same reason because you can just hunt down a new tank (or add a upper stress bar and substitut a small top tank).
But final choice comes down to personal taste, neither are hugely more difficult that the other, both have their own appeals.
aaahahahaaaa great answer
both are great options, i dont think you'd regret either. Probably the best move is to judge on the condition of the bikes. also if the hobbit is a pa50-i slow model, hard pass - derestricting the slow hobbits is a pain, but derestricting a slow maxi is negligible. the only thing making hobbits harder to work on really is the carb is a bitch to get to, but on puch it's stupid easy. But either one I could rebuild in an afternoon, great parts availability, community know-how, great bikes and good beginner bikes too, easier than other makes.
also, as a new rider, i'll save you some trouble and note that rebel moby's posts, including the above (which echos the sentiment of my post), are often very good advice. and anything posted by don ohio is proably best ignored ;)
again I'll reiterate, both great options, and best bet is to judge on personal attraction and cost/condition of the actual bikes in question
> some opinions:
the big difference is that puchs are a more simplistic older technology (50's tech) solution, the hondas are a more modern (late 70's, really 80's tech)
i've owned both but i always sell the hondas off, they are fast, reliable, super easy to work on (don't believe the hype about the carbs, they are easy peasy) smooth and comfortable, that said i don't enjoy working on them as much and they bore me.
compared to cars, the puch maxi is the vw beetle of mopeds, the honda is a very honda-like early 80's civic perhaps. They are both pretty similar size, weight, even performance but the honda accomplishes everything using more modern design, its still not complex or hard to work on, but using modern technology things tend to be slightly more convoluted, but better in many ways.
depending on how much you want to spend, you'll probably just end up owning whatever comes along first within your price range, most people around here find our mopeds however they pop up and learn to love them as we fix them up.
i'm always a fan of steering people towards the puch (e50), tomos, minarelli v1 as first mopeds because they tend to be the most forgiving. any one of those three will run just about no matter what. i've had a few hobbits over the years that were just total dickbags and fought me all the way up until a full rebuild
I see that I am considering 2 very good models of mopeds.
I am leaning towards the Hobbit.
Turn signals
The CVT for hills
The amazing performance potential
Thanks everyone!
I missed Tomos earlier!
Thank you and yes, i will keep away from rust, both inside the tank and out.
Hello Jeffrey, showing your age ''era'' there right along with me!
Thanks Thomas, Puch guy I see with your Maxi Luxe, nice I'm sure. I appreciate it.
Thanks Nick, now I have to decide if i want my moped's carb is to be the hard to clean Keihin or a Bing that leaks?
Lol
Rebel, thanks for taking time to respond, with all that info.
There's a word ya don't hear very often....monocoque.
All one piece hollow frame?
So the Puch is monocoque but not the Hobbit, correct?
Or are all mopeds monocoque?
Will, thanks also for taking the time to chime in with your opinions.
Graham, great explanations and comparisons with lots of super info!
Much appreciate your time and knowledge.
Thanks again and I hope I didn't miss anyone.
It's Japanese
It has turn signals after 1980
The CVT for hills
I'm a hobbit boi, but go for whatever is decent for a good price. With wall of text from your initial comment it seems that you'll be fine with whatever you end up with.
Puch !
i think theyre both great but honestly the forks on a hobbit are just the worst. the work fine but the angle is awful and its a deal breaker for me, otherwise id own a dozen of them
Deal breakers I gotta find out more about What's up with the Honda's forks?
Something about the rake being too stout I remember.
What is a stout rake? Too slanted or not slanted enough?
Thanks Alex and Avery.
Alex I see has a super bad Honda cafe racer. With a sword it appears. Whoa. Jacket and all. Thumbs up.
Avery is diehard with a sweet blue Maxi, in the snow with snow tires on i bet.
Guessing Josh is gonna say the forks are too straight up and down for his liking.
