Re: Hobbits or Maxis? i'm torn between 2 lovers.
- schmiddy /
I disagree with the above testimonials. Both Puchs (Maxi) and Honda Hobbits are fine but both have drawbacks too.
The Maxi’s interval tank is mighty inconvenient to clean out if it’s rusty but the hobbit tank is a horrible design to do the same. Pinto/Swinger or Free Spirit have removable tanks that are super easy to maintain.
Puchs are stupid simple. There’s only a dozen or so moving parts/components in an E50 and they are probably to most reliable, durable and forgiving engines I’ve ever worked on. Parts are cheap and available everywhere. The PA engine and drive system is a far more advanced design but It never liked having to drop the engine to get to the carburetor - which you’d have to do (repeatedly) when it gets dirty, and that Kehlin carb is bloody awful.
The Honda PAII is dual variated, which is great for rapid acceleration and climbing hills. It’s a system capable of amazing performance potential. Avoid the single variated PAI though.
Hobbit electrics are a dumb, fucked up mess. Just remove the headlight lamp and take a look at the rat’s nest behind it. I could go on nit picking the Hobbit but their engine is outstanding; everything else bolted onto it is way overrated in my honest opinion.
  Hobbits or Maxis? i'm torn between 2 lovers.Topic by: Piston Broke Piston Broke 10/21/19 07:28PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: P D P D 10/21/19 08:42PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/21/19 08:48PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/21/19 08:55PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: * * * * 10/21/19 09:32PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Rex Sheler Rex Sheler 10/21/19 09:38PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Bas Autowas Bas Autowas 10/21/19 10:01PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Potr zebie Potr zebie 10/22/19 10:50AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: - schmiddy - schmiddy 10/21/19 10:03PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/21/19 10:52PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Stephen Keller Stephen Keller 10/22/19 05:11AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Tomos A35 Tomos A35 10/22/19 06:18AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Chris Szuba Chris Szuba 10/22/19 06:37AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Bad Cadillac™ Bad Cadillac™ 10/22/19 06:45AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: ***Kim Jong illest*** ***Kim Jong illest*** 10/22/19 07:44AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Dave Steele Dave Steele 10/22/19 09:54AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Graham Motzing Graham Motzing 10/22/19 02:12PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 08:39AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Jeffrey Strichart Jeffrey Strichart 10/22/19 10:21AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Thomas Peffer Thomas Peffer 10/22/19 10:23AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/22/19 10:29AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Rebel Moby Rebel Moby 10/22/19 10:45AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Born to be WillD Born to be WillD 10/22/19 11:03AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 04:12PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Rebel Moby Rebel Moby 10/23/19 09:53AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 04:15PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Alex Gween Blastard Alex Gween Blastard 10/22/19 07:31PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Avery M. Avery M. 10/22/19 08:07PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Nick Haber Nick Haber 10/22/19 10:21PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: ***Kim Jong illest*** ***Kim Jong illest*** 10/22/19 09:25PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 09:31PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/22/19 09:45PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: pat splat pat splat 10/23/19 08:30AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/23/19 03:52PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/23/19 09:46AM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/23/19 03:54PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/23/19 04:13PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Piston Broke Piston Broke 10/23/19 05:41PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Trent Anderson Trent Anderson 10/23/19 01:56PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Overpriced Parts Overpriced Parts 10/23/19 04:50PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Juan Grandé Juan Grandé 10/23/19 04:05PM
  Re: Hobbits or Maxis? i'm torn between 2 lovers.Re: Trent Anderson Trent Anderson 10/23/19 10:17PM
