Re: What do I have?
Jimmy Cincinnati /
That is a good looking tomos! Upjetting the carb and throwing a new pipe on would work wonders, those stock curvy tomos pipes are very restrictive. Whatever you do, keep the carb under the tank, the straight shot intakes really help with power. The aftermarket curvy intakes suck plus they are only 13.5mm (not the 15mm advertised). Id drill your intake out to about 14.5mm than get a 15mm sha. Also, any of the cheap 70cc kits are decent to run.
