> Saabsonettguy . Wrote:
> It does look like an sp50. The stock motor is an AV7, but it takes the
> cylinder head with the tall engine mount like an av88 or av89 uses. I
> assume an AV10 would work too, with the proper head. There may be other
> work involved, not sure on the driven pulley clearance, lower spring
> mount etc, but it's probably doable without too much trouble.
Thanks! I knew I’d need a different head if it was an AV7, but I wasn’t sure if that’s what came with it
