If I’m not mistaken this is an SP50 correct? And will an AV7 or AV10 bolt on?
SP50 Help
Re: SP50 Help
It does look like an sp50. The stock motor is an AV7, but it takes the cylinder head with the tall engine mount like an av88 or av89 uses. I assume an AV10 would work too, with the proper head. There may be other work involved, not sure on the driven pulley clearance, lower spring mount etc, but it's probably doable without too much trouble. (edited)
Re: SP50 Help
Thanks! I knew I’d need a different head if it was an AV7, but I wasn’t sure if that’s what came with it
