Re: Rectifiers and regulators
el pollo /
> Graham Motzing Wrote:
> well this thread has turned into a total shitshow, this el pollo is just
> blathering crazy nonsense. I cant figure out what the hell he is on
> about.
> are you trying to run LED lights?
> the coil you have is not a floated ground coil, its dual tapped. I just
> recently started experimenting with these and the china regulators
> designed for them, basically its like two coils in one, but they are
> both grounded. you can't hook them up to the two AC poles of the
> rectifier the way you probably think you can.
> they are meant to be run with a dual-mode wiring schematic like this
> one:
> 1983 passport
> the white and yellow wires are the two 'taps' on the lighting coil. one
> directly drives the headlight and the other one gets rectified to a
> battery. this way you have plenty of power for a ripping headlight and
> you can charge a battery without overpowering it.
another ma poster that knows nothing but posts like he knows. stator coils can be added by running them in series or running them through a rectifier.
in order to do the conversion the center tap is not used. use the headlight wire only. I've already posted a full wave ac to dc one wire solution.
  Rectifiers and regulatorsTopic by: Jeff Parr Jeff Parr 10/18/19 02:31PM
  Re: Rectifiers and regulatorsRe: Dave Steele Dave Steele 10/18/19 02:39PM
  Re: Rectifiers and regulatorsRe: Rebel Moby Rebel Moby 10/18/19 03:04PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/18/19 03:10PM
  Re: Rectifiers and regulatorsRe: glue baby glue baby 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/18/19 08:27PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 01:02AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 08:50AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 11:06AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 12:56PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 01:05PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 02:17PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/19/19 08:17AM
  Re: Rectifiers and regulatorsRe: Pushrod Fifty Pushrod Fifty 10/19/19 09:02AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/19/19 10:27AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/19/19 12:41PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/19/19 01:41PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/19/19 02:17PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/19/19 03:19PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/20/19 08:28AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/20/19 04:27PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 04:44PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 04:55PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 12:07AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/29/19 11:19PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 11:51PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 05:16PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/20/19 05:53PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/20/19 10:44PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/21/19 01:40PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 04:10PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/21/19 04:46PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 05:56PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 06:21PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/22/19 11:34AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 07:47AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/21/19 06:43PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/22/19 02:34PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/22/19 04:14PM
  Re: Rectifiers and regulatorsRe: Joe Cowabunga Joe Cowabunga 10/23/19 12:54AM
  Re: Rectifiers and regulatorsRe: Ryan Graeme Ryan Graeme 10/23/19 05:51AM
  Re: Rectifiers and regulatorsRe: Joe Cowabunga Joe Cowabunga 10/23/19 06:37AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/23/19 11:01AM
  Re: Rectifiers and regulatorsRe: * * * * 10/29/19 02:45AM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 08:05AM
  Re: Rectifiers and regulatorsRe: * * * * 10/29/19 08:31PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/29/19 11:53PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/30/19 11:19AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/30/19 12:07PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/30/19 06:25PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 12:22AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 04:56PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/30/19 05:10PM
  Re: Rectifiers and regulatorsRe: P D P D 10/30/19 05:15PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 05:49PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 06:11PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 07:16PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/13/19 10:35PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 08:50AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 09:23AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 09:30AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 10:53AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 11:39AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 11:36AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 02:11PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 02:41PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 05:24PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 09:20PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 11/14/19 09:54PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/15/19 07:30AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/15/19 08:57AM
