> Larry Baltz Wrote:
> My company installs a lot of lighting control systems and I was thinking
> that we have had problems dimming track mounted LED retrofit bulbs from
> time to time as they will flicker. A while back I realized that the
> track head is feeding (through a transformer) 12VAC to these MR16 bulbs
> and that the dimming quality was directly related to the bulb
> manufacturer/model#. I knew the rectifier circuitry had to be built into
> the bulb so I took one apart and sure enough there was a little circuit
> board.
> Fast forward to my current Moped project and it occurred to me last week
> that those little circuit boards could be a down and dirty (and cheap)
> way to get a tiny little rectifier anywhere you want a 12V LED bulb. I
> have tested the output from the board and sure enough, 12VAC in (from a
> TrailTech regulator) and 12VDC out.
> The MR16 bulb form factor is entirely wrong for the extremely limited
> space I have to work with so I'm not sure of the solution for what bulb
> to use yet. The 50watt equivalent MR16 draws 7 watts so I'll stay in
> that range.
> I will post photos once I get further assuming the whole thing pans out.
Good luck with impressing any of this upon anyone here. Ive been inserting this in just about every thread about lighting on this forum for a few years now. Even the part about cannibalizing the little driver board inside the mr16s for your choice of led smd or bulb.
Cue the tumbleweeds and cricket chorus. I dont git it.
"Thanks, really! But id just as soon reinvent this here wheel." (edited)
