Re: Rectifiers and regulators
Graham Motzing /
well this thread has turned into a total shitshow, this el pollo is just blathering crazy nonsense. I cant figure out what the hell he is on about.
are you trying to run LED lights?
the coil you have is not a floated ground coil, its dual tapped. I just recently started experimenting with these and the china regulators designed for them, basically its like two coils in one, but they are both grounded. you can't hook them up to the two AC poles of the rectifier the way you probably think you can.
they are meant to be run with a dual-mode wiring schematic like this one:
1983 passport
the white and yellow wires are the two 'taps' on the lighting coil. one directly drives the headlight and the other one gets rectified to a battery. this way you have plenty of power for a ripping headlight and you can charge a battery without overpowering it.
its what was called a 'balanced' system, works great (reliable) with fewer components to fail... back in the day regulators were expensive and unreliable... but they don't work well with modified engines turning higher rpms or modifications to the electrical system.
if you post up your desired lighting/equipment and loads i can draw you a schematic, i haven't tried the capacitors yet, bought some for a project and ended up going with an SLA instead.
  Rectifiers and regulatorsTopic by: Jeff Parr Jeff Parr 10/18/19 02:31PM
  Re: Rectifiers and regulatorsRe: Dave Steele Dave Steele 10/18/19 02:39PM
  Re: Rectifiers and regulatorsRe: Rebel Moby Rebel Moby 10/18/19 03:04PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/18/19 03:10PM
  Re: Rectifiers and regulatorsRe: glue baby glue baby 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/18/19 08:27PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 01:02AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 08:50AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 11:06AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 12:56PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 01:05PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 02:17PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/19/19 08:17AM
  Re: Rectifiers and regulatorsRe: Pushrod Fifty Pushrod Fifty 10/19/19 09:02AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/19/19 10:27AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/19/19 12:41PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/19/19 01:41PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/19/19 02:17PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/19/19 03:19PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/20/19 08:28AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/20/19 04:27PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 04:44PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 04:55PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 12:07AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/29/19 11:19PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 11:51PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 05:16PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/20/19 05:53PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/20/19 10:44PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/21/19 01:40PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 04:10PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/21/19 04:46PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 05:56PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 06:21PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/22/19 11:34AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 07:47AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/21/19 06:43PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/22/19 02:34PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/22/19 04:14PM
  Re: Rectifiers and regulatorsRe: Joe Cowabunga Joe Cowabunga 10/23/19 12:54AM
  Re: Rectifiers and regulatorsRe: Ryan Graeme Ryan Graeme 10/23/19 05:51AM
  Re: Rectifiers and regulatorsRe: Joe Cowabunga Joe Cowabunga 10/23/19 06:37AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/23/19 11:01AM
  Re: Rectifiers and regulatorsRe: * * * * 10/29/19 02:45AM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 08:05AM
  Re: Rectifiers and regulatorsRe: * * * * 10/29/19 08:31PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/29/19 11:53PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/30/19 11:19AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/30/19 12:07PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/30/19 06:25PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 12:22AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 04:56PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/30/19 05:10PM
  Re: Rectifiers and regulatorsRe: P D P D 10/30/19 05:15PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 05:49PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 06:11PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 07:16PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/13/19 10:35PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 08:50AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 09:23AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 09:30AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 10:53AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 11:39AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 11:36AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 02:11PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 02:41PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 05:24PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 09:20PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 11/14/19 09:54PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/15/19 07:30AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/15/19 08:57AM
