Re: Rectifiers and regulators
el pollo /
like the op says, he has the parts already.
jeff I'm sorry. why don't you complain when I make a mistake.
you have a 50a 2 phase rectifier. dillon gave up on me. and I'm
not explaining things well enough. once the one lighting stator is
attached to the ac regulator. I need to tell you what happens in
the rectifier. sorry again dude. these are the outputs and imputs
at each terminal. this rectifier has 2 ac terminals. 2 phase. you only
want to rectify one ac phase so one 2 of the ac imputs is n/c
at this point you want to set the trail tec to 28vac. If it does not
go this high no biggie. I'll get to it. the output between ground and
the + terminal is now 14v dc. the cap gets attached bettween + and
frame ground. the minus rectifier terminal is -14v regulated minus.
the rectifier - is not used. the bike is already wired with the frame as
ground you are done. frame is - and + is 14v. if you have a blaster
type or if the trail tech voltage does not go that high then you need
to float ground. + is 7v and - is -7v. you float ground by running the
ground that floats at -7v. and isolating the bulbs from the frame.
  Rectifiers and regulatorsTopic by: Jeff Parr Jeff Parr 10/18/19 02:31PM
  Re: Rectifiers and regulatorsRe: Dave Steele Dave Steele 10/18/19 02:39PM
  Re: Rectifiers and regulatorsRe: Rebel Moby Rebel Moby 10/18/19 03:04PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/18/19 03:10PM
  Re: Rectifiers and regulatorsRe: glue baby glue baby 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/18/19 08:27PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 01:02AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 08:50AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 11:06AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 12:56PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 01:05PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 02:17PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/19/19 08:17AM
  Re: Rectifiers and regulatorsRe: Pushrod Fifty Pushrod Fifty 10/19/19 09:02AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/19/19 10:27AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/19/19 12:41PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/19/19 01:41PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/19/19 02:17PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/19/19 03:19PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/20/19 08:28AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/20/19 04:27PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 04:44PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 04:55PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 12:07AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/29/19 11:19PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 11:51PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 05:16PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/20/19 05:53PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/20/19 10:44PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/21/19 01:40PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 04:10PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/21/19 04:46PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 05:56PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 06:21PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/22/19 11:34AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 07:47AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/21/19 06:43PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/22/19 02:34PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/22/19 04:14PM
  Re: Rectifiers and regulatorsRe: Joe Cowabunga Joe Cowabunga 10/23/19 12:54AM
  Re: Rectifiers and regulatorsRe: Ryan Graeme Ryan Graeme 10/23/19 05:51AM
  Re: Rectifiers and regulatorsRe: Joe Cowabunga Joe Cowabunga 10/23/19 06:37AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/23/19 11:01AM
  Re: Rectifiers and regulatorsRe: * * * * 10/29/19 02:45AM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 08:05AM
  Re: Rectifiers and regulatorsRe: * * * * 10/29/19 08:31PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/29/19 11:53PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/30/19 11:19AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/30/19 12:07PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/30/19 06:25PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 12:22AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 04:56PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/30/19 05:10PM
  Re: Rectifiers and regulatorsRe: P D P D 10/30/19 05:15PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 05:49PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 06:11PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 07:16PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/13/19 10:35PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 08:50AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 09:23AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 09:30AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 10:53AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 11:39AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 11:36AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 02:11PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 02:41PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 05:24PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 09:20PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 11/14/19 09:54PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/15/19 07:30AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/15/19 08:57AM
