Re: Rectifiers and regulators
el pollo /
> Rebel Moby Wrote:
> Cheapest device is from pocket bikes - these are also combined
> regulator/rectifier
pocket bikes and scoots. in the combined r/r the rectifier comes first inside the unit.
> Jeff Parr Wrote:
> I already have all the parts, all I need to know is do I install the
> rectifier before or after the regulator.
if its an ac clipper 2 wire then the rectifier comes after the regulator.
> Guthrie Mass Wrote:
> > Jeff Parr Wrote:
> You’re not providing a lot of info, but a rectifier will convert ac to
> dc, so if your regulator is rated to input an arbitrary dc voltage and
> output 12v dc, it would go after the rectifier.
yes that's the way I do it.
> Dirty30 Dillon Wrote:
> Generally, your regulator proceeds the rectifier when they are
> separated.
this is the not the case for antiques, all pre 1975 its rectifier first.
any mechanical regulator is wired this way way.
> ken gilbert Wrote:
> in this case the reg is an ac unit and goes before the rec.
yes it is.
> John Maxson Wrote:
> I have used 6v led bulbs from the big lantern battery flashlights, they
> can take higher voltages at high rpms. I buy the 5.00 home depot ones
> and heat glue the innards into a dissected headlight bulb housing.
so have I. this is another way.
puch 12 volt light coil
trail tech dial-a-brightness
NTE53016 Silicon Bridge Rectifier
And last but not least
Aluminum Electrolytic Capacitors
there usually are 2 ac wires coming out of the stator. if you say there is only 1
wire coming out of the stator then the other side is ground. the order is
trail tech clipper ac regulator first then the rectifier. the cap wires in the same
way as a battery. the value I use is 63v 22,000uf.
If I saw your post before you bought the parts I would have told you to use
the yamaha blaster regulator because it's $9 on ebay. NTE53016 Silicon Bridge Rectifier is an interesting part. I would like to know why you ordered this part.
its a 3 phase rectifier. you only have one phase. in order to wire this in you
will have a lot of terminals unconeected. next time for 1 or 2 phases order
the kbpc5010 rectifier.
one important thing to know. the negative terminal will be n/c. you put the regulated.ac stator output goes to any of the 3 ac terminals and you only use the +. if you ground the rectifier in this configuration you will blow up the rectifier.
  Rectifiers and regulatorsTopic by: Jeff Parr Jeff Parr 10/18/19 02:31PM
  Re: Rectifiers and regulatorsRe: Dave Steele Dave Steele 10/18/19 02:39PM
  Re: Rectifiers and regulatorsRe: Rebel Moby Rebel Moby 10/18/19 03:04PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/18/19 03:10PM
  Re: Rectifiers and regulatorsRe: glue baby glue baby 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/18/19 08:27PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 01:02AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 08:50AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 11:06AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 12:56PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 01:05PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 02:17PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/19/19 08:17AM
  Re: Rectifiers and regulatorsRe: Pushrod Fifty Pushrod Fifty 10/19/19 09:02AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/19/19 10:27AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/19/19 12:41PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/19/19 01:41PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/19/19 02:17PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/19/19 03:19PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/20/19 08:28AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/20/19 04:27PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 04:44PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 04:55PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 12:07AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/29/19 11:19PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 11:51PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 05:16PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/20/19 05:53PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/20/19 10:44PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/21/19 01:40PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 04:10PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/21/19 04:46PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 05:56PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 06:21PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/22/19 11:34AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 07:47AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/21/19 06:43PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/22/19 02:34PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/22/19 04:14PM
  Re: Rectifiers and regulatorsRe: Joe Cowabunga Joe Cowabunga 10/23/19 12:54AM
  Re: Rectifiers and regulatorsRe: Ryan Graeme Ryan Graeme 10/23/19 05:51AM
  Re: Rectifiers and regulatorsRe: Joe Cowabunga Joe Cowabunga 10/23/19 06:37AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/23/19 11:01AM
  Re: Rectifiers and regulatorsRe: * * * * 10/29/19 02:45AM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 08:05AM
  Re: Rectifiers and regulatorsRe: * * * * 10/29/19 08:31PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/29/19 11:53PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/30/19 11:19AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/30/19 12:07PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/30/19 06:25PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 12:22AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 04:56PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/30/19 05:10PM
  Re: Rectifiers and regulatorsRe: P D P D 10/30/19 05:15PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 05:49PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 06:11PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 07:16PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/13/19 10:35PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 08:50AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 09:23AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 09:30AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 10:53AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 11:39AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 11:36AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 02:11PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 02:41PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 05:24PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 09:20PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 11/14/19 09:54PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/15/19 07:30AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/15/19 08:57AM
