Re: Rectifiers and regulators
Graham Motzing /
it depends on what type of regulator and rectifier you are using
the rectifier will see the load from the regulator if you install it downstream so you might end up putting a lot of current through the rectifier if you put the regulator after the rectifier
but the regulator will only end up having to do half wave regulation and will be more accurate because it won't have the voltage drop from the rectifier so thats good
if i'm doing a 2 wire setup, where the regulator is taking unregulated AC in and outputting regulated AC, i'll do that right to the AC wire of the stator, then run the headlight off the regulated AC and run the diode right before it gets to the battery
if i'm running a 1 wire regulator i'll do the diode first and put the 1 wire regulator tee'd into the DC side of the circuit.
but like, seriously, combo reg/rec units are so much easier and better , the only time i do separate shenanigans is if i'm working with a bike that has marginal power output or if i have a very old wiring system that i'm trying to keep everything working 'as stock'
  Rectifiers and regulatorsTopic by: Jeff Parr Jeff Parr 10/18/19 02:31PM
  Re: Rectifiers and regulatorsRe: Dave Steele Dave Steele 10/18/19 02:39PM
  Re: Rectifiers and regulatorsRe: Rebel Moby Rebel Moby 10/18/19 03:04PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/18/19 03:10PM
  Re: Rectifiers and regulatorsRe: glue baby glue baby 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/18/19 08:27PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 01:02AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 08:50AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 11:06AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 12:56PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 01:05PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/21/19 02:17PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/18/19 03:32PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/19/19 08:17AM
  Re: Rectifiers and regulatorsRe: Pushrod Fifty Pushrod Fifty 10/19/19 09:02AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/19/19 10:27AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/19/19 12:41PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/19/19 01:41PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/19/19 02:17PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/19/19 03:19PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/20/19 08:28AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/20/19 04:27PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 04:44PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 04:55PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 12:07AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/29/19 11:19PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 11:51PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/20/19 05:16PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/20/19 05:53PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/20/19 10:44PM
  Re: Rectifiers and regulatorsRe: ken gilbert ken gilbert 10/21/19 01:40PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 04:10PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/21/19 04:46PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 05:56PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 10/21/19 06:21PM
  Re: Rectifiers and regulatorsRe: Graham Motzing Graham Motzing 10/22/19 11:34AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 07:47AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 10/21/19 06:43PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/22/19 02:34PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/22/19 04:14PM
  Re: Rectifiers and regulatorsRe: Joe Cowabunga Joe Cowabunga 10/23/19 12:54AM
  Re: Rectifiers and regulatorsRe: Ryan Graeme Ryan Graeme 10/23/19 05:51AM
  Re: Rectifiers and regulatorsRe: Joe Cowabunga Joe Cowabunga 10/23/19 06:37AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/23/19 11:01AM
  Re: Rectifiers and regulatorsRe: * * * * 10/29/19 02:45AM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/29/19 08:05AM
  Re: Rectifiers and regulatorsRe: * * * * 10/29/19 08:31PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/29/19 11:53PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/30/19 11:19AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/30/19 12:07PM
  Re: Rectifiers and regulatorsRe: Larry Baltz Larry Baltz 10/30/19 06:25PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 12:22AM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 04:56PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 10/30/19 05:10PM
  Re: Rectifiers and regulatorsRe: P D P D 10/30/19 05:15PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 05:49PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 06:11PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 10/30/19 07:16PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/13/19 10:35PM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 08:50AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 09:23AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 09:30AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 10:53AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/14/19 11:39AM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 11:36AM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 02:11PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 02:41PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/14/19 05:24PM
  Re: Rectifiers and regulatorsRe: Jeff Parr Jeff Parr 11/14/19 09:20PM
  Re: Rectifiers and regulatorsRe: Brad William Brad William 11/14/19 09:54PM
  Re: Rectifiers and regulatorsRe: el pollo el pollo 11/15/19 07:30AM
  Re: Rectifiers and regulatorsRe: Dirty30 Dillon Dirty30 Dillon 11/15/19 08:57AM
