Re: Pw50 motor to qt50
Jack Rutherford /
I put pw50 charge coils on my qt50s all the time. The difference is the light coil.
If you want to run the lights, you'll need a qt50 lighting coil. The easy thing to do is put the qt50 stator in the pw50 engine (then the stator will have the right 4 plug connector and the proper lighting coil - see below).
If you are putting a pw50 engine on a qt50 then the connection from the stator to the wiring harness is different (see above). You can easily just make them all single wire connections instead of using the 3 or 4 prong plugs. The battery does act as a regulator but if you have a qt50 with a 3 position switch then there is also a separate regulator on the frame. If it were me, I would just strap on a battery because the battery provides power to the turn signals, horn and brake/tail light. (edited)
  Pw50 motor to qt50Topic by: Pops Peds Pops Peds 10/18/19 09:39AM
  Re: Pw50 motor to qt50Re: Angry Hipster Angry Hipster 10/18/19 11:15AM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/18/19 05:36PM
  Re: Pw50 motor to qt50Re: Jack Rutherford Jack Rutherford 10/18/19 05:57PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/18/19 06:47PM
  Re: Pw50 motor to qt50Re: Stephen Keller Stephen Keller 10/18/19 06:08PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/18/19 07:14PM
  Re: Pw50 motor to qt50Re: Stephen Keller Stephen Keller 10/18/19 07:21PM
  Re: Pw50 motor to qt50Re: Jack Rutherford Jack Rutherford 10/20/19 01:29PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/18/19 07:32PM
  Re: Pw50 motor to qt50Re: Stephen Keller Stephen Keller 10/18/19 10:08PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/18/19 10:24PM
  Re: Pw50 motor to qt50Re: Stephen Keller Stephen Keller 10/18/19 10:43PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/18/19 10:52PM
  Re: Pw50 motor to qt50Re: Stephen Keller Stephen Keller 10/18/19 11:02PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/19/19 06:08AM
  Re: Pw50 motor to qt50Re: Angry Hipster Angry Hipster 10/19/19 07:24AM
  Re: Pw50 motor to qt50Re: Full Tuck Full Tuck 10/19/19 11:04AM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/19/19 02:12PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/20/19 06:59PM
  Re: Pw50 motor to qt50Re: Stephen Keller Stephen Keller 10/20/19 09:59PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/21/19 05:06AM
