Re: Pw50 motor to qt50
Full Tuck /
I've swapped QT50 onto a towney frame.
Going from QT50 to PW50 you're gonna need to:
1) swap out the drive shaft assembies. From your QT50, use the rear shock, wheel, rear hub, and drive shaft. This will ensure you have the right final drive ratio and engine+wheel geometries fo the handling doesn't get any worse.
2) The wiring is almost certainly different, you may need to swap the stators cause PW50 doesn't have lights. Yamaha flywheels have a puller unlike most other mopeds, but they are easy to buy online.
3) throttle cables may be different. Use the PW50 throttle cable, caburetor and airbox.
4) a towney motor cannot be easily mounted on a QT50. Transmission parts for towny's are not availible. Towny has a different exhaust thas not compatible. Id stick with the one speed motors so you can fix/maintain it easily. (edited)
  Pw50 motor to qt50Topic by: Pops Peds Pops Peds 10/18/19 09:39AM
  Re: Pw50 motor to qt50Re: Angry Hipster Angry Hipster 10/18/19 11:15AM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/18/19 05:36PM
  Re: Pw50 motor to qt50Re: Jack Rutherford Jack Rutherford 10/18/19 05:57PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/18/19 06:47PM
  Re: Pw50 motor to qt50Re: Stephen Keller Stephen Keller 10/18/19 06:08PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/18/19 07:14PM
  Re: Pw50 motor to qt50Re: Stephen Keller Stephen Keller 10/18/19 07:21PM
  Re: Pw50 motor to qt50Re: Jack Rutherford Jack Rutherford 10/20/19 01:29PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/18/19 07:32PM
  Re: Pw50 motor to qt50Re: Stephen Keller Stephen Keller 10/18/19 10:08PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/18/19 10:24PM
  Re: Pw50 motor to qt50Re: Stephen Keller Stephen Keller 10/18/19 10:43PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/18/19 10:52PM
  Re: Pw50 motor to qt50Re: Stephen Keller Stephen Keller 10/18/19 11:02PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/19/19 06:08AM
  Re: Pw50 motor to qt50Re: Angry Hipster Angry Hipster 10/19/19 07:24AM
  Re: Pw50 motor to qt50Re: Full Tuck Full Tuck 10/19/19 11:04AM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/19/19 02:12PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/20/19 06:59PM
  Re: Pw50 motor to qt50Re: Stephen Keller Stephen Keller 10/20/19 09:59PM
  Re: Pw50 motor to qt50Re: Pops Peds Pops Peds 10/21/19 05:06AM
