Re: Frame Building - race bike for next season
Cheap update..going with an aluminum frame. Im learning fusion 360 and will be building it in here, then prototyping with plywood.
I was just reading about the Walwin grasstrack frames of the 70's - aluminum plate bolted together sandwich <10 lbs sans swingarm (tubular steel). Yetmans are around 8 in chromoly.
Victor Pagan had/has a Bidalot RS1 replica frame done up in aluminum - you could look at a machine like that or the peugeot xg3 for ballpark geometry and scale.
a single plane box section seems to do the trick too. Foale made some cool spine frames.
man that is a cool frame. I wonder if Victor still has that aluminum frame. It was for sale when he was getting out of the game.
Dirty30 Dillon /
I seem to recall a Mass guy buying it, might have been Andy Townsend?
Liked.
Def coming back to this site for this thread in particular
Took a break during the holidays, and started tinkering with a stock+ class engine. Im unsure what ill be racing this on. Maybe just a stock frame. Maybe just a loaner bike.
I had this pipe from a few years back. Its for a morini. I attempted to weld it to a cast iron cylinder around 2011. That obviously didnt work, and since then ive learned more about welding.
My gila pipe header was really nice thanks to a friend and a mill. This one is thinner than id like, but very close to square, while using a drill press and a gasket.
The cylinder needed the exhaust exit port walls ground down to accomodate. That took the majority of the time.
It is not finished. I need to weld spring retainers and decide how I will mount the stinger/baffle. (edited)
Those little shitters don’t even need a baffle. Especially if it’s just gonna be a track bike.
Baffles are required on the track. And I already have the baffle so I may as well use it
I don't get the "must have silencer" rule. With a full face helmet you can barely hear anything anyway. I mean, if you're running a megaphone exhaust like the old days before xchambers I could imagine it pissing people off, but a loud bike on a track is just... Normal.
My center bleed pipe with no silencer is quieter than almost every bike with a muffler.
> with a muffler.
Yea the center bleed is very quiet. A 6" narrow stinger on any kitted bike would be loud though.
Finished the spring mounts this morning..
sweet!
is that still steel fill rod? - silicon bronze is the way to go on thin stuff and will reduce the opportunity for that undercutting to develop.
> jumpsuit steve Wrote:
> sweet!
yea, i could have brazed it too. I decided to weld it for practice tbh.
I'm building an exhaust for my 1989 e30 bmw and needed to get warmed up.
https://instagram.com/mikey.antonakakis?igshid=n2hjf7fgyz15
This dude just made a turbo exhaust manifold for his bmw. Came out pretty sick.
> pretty sick.
Thats really nice. I'm keeping mine NA with the stock engine. Its chipped and has a k&n, and cat delete. I have long headers on mine. I have the 325ix, so AWD, 67% pwr to the rear wheels. 5 speed swap. Mtech package but ive stripped the interior and will be making a B pillar brace for 5 pt harnesses.
/\ very nice!
Well the pieces are coming together.
Ty Lou for swinging the arrow parts my way for a killer deal.
I'm getting into the mock up stage. I picked up some plywood to build the plate frame out.
I'm making these motor mounts to compensate for the front motor mount. It has a 22mm offset.
The challenge will be the clutch side. The drive side is easy, as long as I account for the chain line I should be all set.
Also, i may have to lengthen my single sided swingarm. From the factory its incredibly short.
Please spend some time making the wheel adjuster not garbage on this. By far the biggest bummer about the arrow/racing to. I think a ds50 swingarm and wheel would have been a better choice for simplicity’s sake. But man, a single sided swingarm with a mono shock is gonna be sick. Matching wheels is a plus too. They also make some really good 12” race tires too, so that’s a pretty rad advantage of having arrow sized wheel.
> wheel.
Yep. That snail and double bolt is nonsense and absolutely a headache for a race bike.
Anything I do there ill include specs and a file.
Mock up taking basic shape.
After talking with some friends I have a gameplan for the swingarm. Sleeve and extend 2-3 inches, notch the snail to avoid slip, and use a cam on the swingarm thru bolt and frame.
My swingarm and forks will be waaaaay heavier than my frame.
More to come
Getting some geometry and mock up going
I love this it’s exactly what I wanted to do with a derbi furax I just didn’t have the cash when it popped up . I rode a mini moto set up xr100 last year and that thing is a blast I’m building my racebike to hopefully feel similar to that
This is the plate shape. Seat stays will be bolt on.
