Took a break during the holidays, and started tinkering with a stock+ class engine. Im unsure what ill be racing this on. Maybe just a stock frame. Maybe just a loaner bike.
I had this pipe from a few years back. Its for a morini. I attempted to weld it to a cast iron cylinder around 2011. That obviously didnt work, and since then ive learned more about welding.
My gila pipe header was really nice thanks to a friend and a mill. This one is thinner than id like, but very close to square, while using a drill press and a gasket.
The cylinder needed the exhaust exit port walls ground down to accomodate. That took the majority of the time.
It is not finished. I need to weld spring retainers and decide how I will mount the stinger/baffle. (edited)
