Well I got the clutch fixed. The plate on #4 hub in previous picture was held on by a cast retaining ring. I ground that ring off, removed the plate and cleaned out the grooves in the hub. I installed all new parts from Myrons in the clutch hub as per his diagram and it works as it should. This clutch operates OPPOSITE as you think of a car clutch. When you pull the clutch handle ( like stepping on clutch pedal) it ENGAGES the clutch to turn the engine over. When you let go of the handle ( like letting clutch pedal out) it DISENGAGES the clutch allowing it to free-wheel. Crazy but simple Austrian /German tech. I worked for VW for 27 years so I had to TRY reprogramming my brain to think opposite.
Re: odyssey with an Odyssey
