Your number to plate is bent if the keyway in the center of your Hub is good all you have to do is find a piece of metal like a tube or a pipe that's the right thing at diameter so that you can whack it with a mallet and reform it so it's out farther it happens when the clutch is where and nobody notices and they keep on gripping the handle Tighter and Tighter and they take up the slack on the stretched cable if you do need one I do have one I have everything except for that Central hub I have it but the key way is Sheera
Re: odyssey with an Odyssey
