Brought this rusty thing home and since it sat for so long I squirted some penetrating oil in the cylinder to limber things up. After putting the spark plug back in and pedaling it I thought I heard a pop. It does have good spark so then I squirted some gas down the plug hole and it started right up and ran for a few seconds. So this may be a somewhat less involved restoration than originally perceived. It is a bit of a mystery as you can see by the VIN plate which matches the foot trim. But the clutch is not a 2 speed. You'd think with only 365 miles on it, it would still have the original set-up. So I'm looking for some ideas / explanations from those of you that have been around mopeds for longer than I.
