drunk or crack. I make my own baja boxes and do my own for less than 10$. 6v or 12v does not matter because I can either make either type. so can you. honestly I usually convert to 12v because its usually a simple rewire at the stator. then I can use a modern flasher and auto led's.
anyone buying crap like this is smoking crack. I am not a commie. the seller is not at fault.
you do not need to study ee. anyone can order tiny bulbs at any voltage. 6v flashlight bulbs use little current and can be fit in any housing. low current turn signals won't work with out a low current flasher. the hyperflash .99 cent 2 wire flasher costs 1$ on ebay for 12v. even the most electrically challenged can run this 6v custom part in the link. unlike leds this part will work fine ac or dc. 6v ac uses a 2 wire Yamaha blaster or kawi kdx 6v offroad ac regulator.
https://www.ebay.com/itm/Flashing-bulb-6-volt-200-mA-M-E-S-E10-screw-pack-of-10-/301875777572
this is not a rant. hopefully someone here reads this and saves some $. release your inner mechanic by going out of manual. order parts by spec and lowest cost. do not listen to websites that pretend to help but only want to sell you over priced rick sprack Oregon
