Re: 190$ For Cateye's... Who's Drunk??
el pollo /
drunk or crack. I make my own baja boxes and do my own for less than 10$. 6v or 12v does not matter because I can either make either type. so can you. honestly I usually convert to 12v because its usually a simple rewire at the stator. then I can use a modern flasher and auto led's.
anyone buying crap like this is smoking crack. I am not a commie. the seller is not at fault.
you do not need to study ee. anyone can order tiny bulbs at any voltage. 6v flashlight bulbs use little current and can be fit in any housing. low current turn signals won't work with out a low current flasher. the hyperflash .99 cent 2 wire flasher costs 1$ on ebay for 12v. even the most electrically challenged can run this 6v custom part. unlike leds it will work fine ac or dc. 6v ac uses a 2 wire Yamaha blaster 6v ac regulator.
https://www.ebay.com/itm/Flashing-bulb-6-volt-200-mA-M-E-S-E10-screw-pack-of-10-/301875777572
this is not a rant. hopefully someone here reads this and saves some $. release your inner mechanic by going out of manual. order parts by spec and lowest cost. do not listen to websites that pretend to help but only want to sell you over priced rick sprack Oregon.
  190$ For Cateye's... Who's Drunk??Topic by: Road Kill Road Kill 10/12/19 06:48AM
  Re: 190$ For Cateye's... Who's Drunk??Re: Road Kill Road Kill 10/12/19 06:49AM
  Re: 190$ For Cateye's... Who's Drunk??Re: el pollo el pollo 10/12/19 08:05AM
  Re: 190$ For Cateye's... Who's Drunk??Re: el pollo el pollo 10/12/19 08:19AM
  Re: 190$ For Cateye's... Who's Drunk??Re: Probably Fred Probably Fred 10/12/19 01:05PM
  Re: 190$ For Cateye's... Who's Drunk??Re: Moped Lar Moped Lar 10/12/19 02:40PM
  Re: 190$ For Cateye's... Who's Drunk??Re: Stephen Keller Stephen Keller 10/12/19 03:29PM
  Re: 190$ For Cateye's... Who's Drunk??Re: Probably Fred Probably Fred 10/12/19 05:34PM
  Re: 190$ For Cateye's... Who's Drunk??Re: Stephen Keller Stephen Keller 10/12/19 06:21PM
  Re: 190$ For Cateye's... Who's Drunk??Re: Probably Fred Probably Fred 10/12/19 06:55PM
  Re: 190$ For Cateye's... Who's Drunk??Re: Stephen Keller Stephen Keller 10/12/19 07:01PM
  Re: 190$ For Cateye's... Who's Drunk??Re: el pollo el pollo 10/12/19 07:15PM
  Re: 190$ For Cateye's... Who's Drunk??Re: Stephen Keller Stephen Keller 10/12/19 07:20PM
  Re: 190$ For Cateye's... Who's Drunk??Re: el pollo el pollo 10/14/19 08:00PM
  Re: 190$ For Cateye's... Who's Drunk??Re: el pollo el pollo 10/12/19 07:22PM
  Re: 190$ For Cateye's... Who's Drunk??Re: el pollo el pollo 10/12/19 06:59PM
  Re: 190$ For Cateye's... Who's Drunk??Re: Probably Fred Probably Fred 10/12/19 07:06PM
  Re: 190$ For Cateye's... Who's Drunk??Re: Stephen Keller Stephen Keller 10/12/19 07:28PM
  Re: 190$ For Cateye's... Who's Drunk??Re: el pollo el pollo 10/12/19 07:55PM
