Re: 1977 Lazer 50 key needed
ID OD /
> jeff forty Wrote:
> Thanks all got the tank open/cleaned out, runs great after a rebuild of
> carb, now to figure out the electrical issue so all the lights work..
so how did you get it open? my first general took a lot of sorting out electrically to make everything work as it should. the serious bird nest of wiring took a lot of patience. the wiring diagram in the RIGHT manual, and some wiring diagrams found on line eventually made it happen. it truly was a nightmare however, different wiring diagrams (minarelli vs sachs), bad wires, blown fuses, blown bulbs, faulty rectifier, grounding issues, battery, blah blah blah. in the end it all worked correctly for a stinking month before it took a shit again. pissed off, i hard wired it with running lights, and regretfully sold it for what i paid for it $300. i now have 2 generals, and a lazer, and will never take on that shit again especially when its not need to be legal. they are all hard wired with running lights. done and done. the sad part about it all is 3 of 4 i've own/owned were minty, and it drove me nuts to not have them operating oem correct. just fyi ive seen quite a few generals/lazers, and not one operates oem as it should. good luck with it. show us some pics. they are my wife, and daughters favorite bikes.
  1977 Lazer 50 key neededTopic by: jeff forty jeff forty 10/11/19 10:06AM
  Re: 1977 Lazer 50 key neededRe: Probably Fred Probably Fred 10/11/19 11:41AM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 10/11/19 02:17PM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 10/14/19 10:04AM
  Re: 1977 Lazer 50 key neededRe: ID OD ID OD 10/14/19 01:59PM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 10/21/19 02:55PM
  Re: 1977 Lazer 50 key neededRe: ID OD ID OD 10/21/19 07:56PM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 10/22/19 09:53AM
  Re: 1977 Lazer 50 key neededRe: Rebel Moby Rebel Moby 10/22/19 10:07AM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 10/22/19 10:22AM
  Re: 1977 Lazer 50 key neededRe: Chris Squid Chris Squid 10/11/19 02:27PM
  Re: 1977 Lazer 50 key neededRe: kenny s kenny s 10/11/19 09:47PM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 10/12/19 04:34PM
  Re: 1977 Lazer 50 key neededRe: ID OD ID OD 10/22/19 03:26PM
  Re: 1977 Lazer 50 key neededRe: ID OD ID OD 10/22/19 03:47PM
  Re: 1977 Lazer 50 key neededRe: ID OD ID OD 10/22/19 03:59PM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 10/24/19 12:54PM
  Re: 1977 Lazer 50 key neededRe: Chris Squid Chris Squid 10/22/19 04:14PM
  Re: 1977 Lazer 50 key neededRe: ID OD ID OD 10/22/19 04:21PM
  Re: 1977 Lazer 50 key neededRe: Chris Squid Chris Squid 10/22/19 06:05PM
  Re: 1977 Lazer 50 key neededRe: Saint Upjet Saint Upjet 10/26/19 12:27PM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 11/04/19 09:42AM
