Re: 1977 Lazer 50 key needed
ID OD /
> jeff forty Wrote:
> can you be more specific where to place screwdriver, tanks mint dont
> want to damage
fork key is not the same as tank. if you look you will see the latch under the stationary bar from the front. you just push the latch back and it pops open. you use a thin straight blade screwdriver. ive also used a number of small keys, i.e. gun lock key, suitcase key, diary key, and had success. use little keys cut on both sides. ive got a gunlock key that has opened every general/lazer tank ive used it on. dont bother with removing hinge pin, its a waste of time, and you can break something.
  1977 Lazer 50 key neededTopic by: jeff forty jeff forty 10/11/19 10:06AM
  Re: 1977 Lazer 50 key neededRe: Overpriced Parts Overpriced Parts 10/11/19 11:41AM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 10/11/19 02:17PM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 10/14/19 10:04AM
  Re: 1977 Lazer 50 key neededRe: ID OD ID OD 10/14/19 01:59PM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 10/21/19 02:55PM
  Re: 1977 Lazer 50 key neededRe: ID OD ID OD 10/21/19 07:56PM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 10/22/19 09:53AM
  Re: 1977 Lazer 50 key neededRe: Rebel Moby Rebel Moby 10/22/19 10:07AM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 10/22/19 10:22AM
  Re: 1977 Lazer 50 key neededRe: Chris Squid Chris Squid 10/11/19 02:27PM
  Re: 1977 Lazer 50 key neededRe: kenny s kenny s 10/11/19 09:47PM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 10/12/19 04:34PM
  Re: 1977 Lazer 50 key neededRe: ID OD ID OD 10/22/19 03:26PM
  Re: 1977 Lazer 50 key neededRe: ID OD ID OD 10/22/19 03:47PM
  Re: 1977 Lazer 50 key neededRe: ID OD ID OD 10/22/19 03:59PM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 10/24/19 12:54PM
  Re: 1977 Lazer 50 key neededRe: Chris Squid Chris Squid 10/22/19 04:14PM
  Re: 1977 Lazer 50 key neededRe: ID OD ID OD 10/22/19 04:21PM
  Re: 1977 Lazer 50 key neededRe: Chris Squid Chris Squid 10/22/19 06:05PM
  Re: 1977 Lazer 50 key neededRe: Saint James Saint James 10/26/19 12:27PM
  Re: 1977 Lazer 50 key neededRe: jeff forty jeff forty 11/04/19 09:42AM
