> Brandon Weiss (Detective brandon to you) Wrote:
> Bosch pint ignitions should give a strong, bright purple spark when set
> up properly.
> Did you replace the condenser? Check your grounds too, make sure they're
> clean and solid. Make sure the plug boot has a good connection with the
> wire, same with the wire to the HT coil. Screw it in snug. If its loosey
> goosey, unscrew it, snip the ends so they're fresh and screw it back in.
I will do those things. I did get a condenser too. Should be here in a couple of days. Thanks.
