Come on guys, you’re just being rude now. Shut up and let him try it, especially since you all suck at trolling.
I have had good luck with 50cc cylinders on a puch. The tccd is pretty good and cheap, but if you want real nice porting you’re gonna have to look into the Athena 50cc kits. The ajh you can use a small spacer and fit big ole 8 petal reeds in. Also there is a piston port Athena 50 that is really fast, have to go to puchshop.de for that one though. Gonna need a hard hitting pipe to pull gear tall enough to reach 60mph or a super high revving set up to be able to reach 13k rpm. I would recommend the latter strategy, grab a homoet 4p, 6p, or simonini. 50cc cylinders are not forgiving to tune and you will have to do a port map/get your degree wheel out, do a little porting (seriously don’t get wild), space and deck the cylinder/head for proper squish the compression ratio. If you don’t do this it will suck and you will absolutely never hit 60.
