> Jeffrey Strichart Wrote:
> -------------------------------------------------------de
> Jet larger for altitude. Anything with a carburetor will run leaner the
> higher you go. So you want a little more fuel. Don't worry about a kit
> yet. Ride it for a while and make sure it is running right before you
> start modding it.
You got that backwards, less air less jet/jetting,
Rear wheel is wrong, front wheel needs fender or fork support or you will wreck,
This is my maxi II with polini kit, true rubber 4 petal reeds and 19 mm phbg 1 hp inside gearing and custom rear 31t rear sprocket
Goes 0 to 55 in seconds and has for 11 years
