Re: lubing a puch freewheel
Probably Fred /
> Rocco Taco Wrote:
> Have you heard of chain lube?
> You can degrease the freewheel then regrease with some chain lube
That is what I do but I use spray grease not sticky chain lube,
Not really relating to the freewheel topic will but Some brands sticky chain lube will make like a cotton candy spiderweb (when you first put it on your chain) blocking a metal mesh filter (if that side or rear mount carb) in a second making you wonder what’s the matter with your freshly kitted bike’s tune,
I use chain wax for my chains if filter is by drive chain,
