Re: Supertech Marine....The low priced oil of Mopeds?
Probably Fred /
> live ɘvil Wrote:
> Well the injectior on an NC50 will beg to differ. It runs best and
> cleanest on Honda 2 stroke injector oil. Ive tried several and
> synthetics fuck with it the most.
I run synthetic oil if manual says to, like my tomos revival manual says to run so I’ve found the best injector oil is this Polaris oil:
I run it in my stock cylinder magnum MKII oil injector also, flows good in all weather.
Plated aluminum cylinder kits (like polini) manuals call for synthetic 2 cycle oil so I run what the manual says but I run all different brands of synthetic and all seem to work pretty good with less carbon and smoother operation then most of the petroleum oil‘s I used for years, years ago,
I think the reverse is true about what was said about seal deterioration I think you get better seal life as well as bearing and bushing life,
Some of my personal bikes (most not stock) I’ve had for over 20 years and when I take them down for inspection/maintenance I’ve noticed less wear in every aspect, top end with synthetic 2t oil as well as gearbox, clutches, bushings and cranks with synthetic 4t oil in the gearboxes instead of just transmission oil,
Stock bike yeah you could use all kinds/brands of regular oil but if running a performance set up or if the manual calls for synthetic, synthetic oil is the way to go.
  Supertech Marine....The low priced oil of Mopeds?Topic by: Angry Hipster Angry Hipster 10/05/19 08:14AM
  Mopeds are not marine craftRe: Rebel Moby Rebel Moby 10/05/19 08:35AM
  Re: Mopeds are not marine craftRe: Angry Hipster Angry Hipster 10/05/19 08:46AM
  Re: Mopeds are not marine craftRe: Rebel Moby Rebel Moby 10/05/19 09:16AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Moped Lar Moped Lar 10/05/19 08:50AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Don Ohio Don Ohio 10/07/19 04:21PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: ♣Slew Foot♣ ♣Slew Foot♣ 10/08/19 11:15AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Double Trouble Dan Double Trouble Dan 10/05/19 09:17AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/05/19 09:37AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: ken gilbert ken gilbert 10/05/19 11:44AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Josiah Radebaugh Josiah Radebaugh 10/05/19 12:09PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/05/19 11:59AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/05/19 12:48PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Probably Fred Probably Fred 10/05/19 01:11PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: pat splat pat splat 10/05/19 08:13PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Stephen Keller Stephen Keller 10/05/19 08:28PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: live ɘvil live ɘvil 10/08/19 12:20AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Probably Fred Probably Fred 10/08/19 12:37PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Tomos A35 Tomos A35 10/06/19 05:15AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: - rwc - - rwc - 10/06/19 08:22AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: ♣Slew Foot♣ ♣Slew Foot♣ 10/06/19 08:44AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Stephen Keller Stephen Keller 10/08/19 03:44AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: live ɘvil live ɘvil 10/08/19 10:47AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Chris Szuba Chris Szuba 10/08/19 06:08AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Bad Cadillac™ Bad Cadillac™ 10/08/19 07:07AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Jeffrey Strichart Jeffrey Strichart 10/08/19 01:22PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Moped Lar Moped Lar 10/08/19 01:52PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/08/19 02:05PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/08/19 02:03PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 10/08/19 04:26PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Dan (high idle) Conway Dan (high idle) Conway 10/08/19 11:48PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: ♣Slew Foot♣ ♣Slew Foot♣ 10/09/19 02:09AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Josiah Radebaugh Josiah Radebaugh 10/09/19 10:13AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Pushrod Fifty Pushrod Fifty 10/09/19 09:03AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/09/19 09:49AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: ♣Slew Foot♣ ♣Slew Foot♣ 10/09/19 11:49PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Born to be WillD Born to be WillD 10/09/19 09:59AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/09/19 10:05AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Born to be WillD Born to be WillD 10/09/19 02:19PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Zach Riddle Zach Riddle 10/09/19 01:11PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Pushrod Fifty Pushrod Fifty 10/09/19 04:03PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Born to be WillD Born to be WillD 10/10/19 09:14AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/10/19 10:12AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Born to be WillD Born to be WillD 10/10/19 10:46AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Born to be WillD Born to be WillD 10/10/19 10:48AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Bas Autowas Bas Autowas 10/10/19 10:58AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/09/19 06:14PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Thomas TPRF Thomas TPRF 10/09/19 11:23PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/10/19 06:38AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Graham Motzing Graham Motzing 10/10/19 11:18AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: no groms no blasters no groms no blasters 10/10/19 10:17AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/10/19 10:53AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/10/19 10:58AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Jack MT Goatheads MPC Jack MT Goatheads MPC 10/16/19 09:44AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Born to be WillD Born to be WillD 10/16/19 10:06AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Josiah Radebaugh Josiah Radebaugh 10/16/19 10:07AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: P D P D 10/16/19 10:17AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/16/19 10:32AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: P D P D 10/16/19 10:49AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/16/19 10:56AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: P D P D 10/16/19 11:35AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/16/19 11:52AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: P D P D 10/16/19 12:04PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Josiah Radebaugh Josiah Radebaugh 10/16/19 12:25PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Dirty30 Dillon Dirty30 Dillon 10/16/19 04:32PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Born to be WillD Born to be WillD 10/16/19 04:40PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Graham Motzing Graham Motzing 10/16/19 04:57PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/16/19 05:09PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Graham Motzing Graham Motzing 10/17/19 02:13PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: ken gilbert ken gilbert 10/17/19 09:08AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: P D P D 10/17/19 09:42AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Josiah Radebaugh Josiah Radebaugh 10/17/19 10:26AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/16/19 10:25AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/16/19 10:14AM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: mit mortso mit mortso 10/16/19 03:22PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/16/19 03:46PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Graham Motzing Graham Motzing 10/16/19 04:11PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/16/19 04:19PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Dirty30 Dillon Dirty30 Dillon 10/16/19 05:15PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Josiah Radebaugh Josiah Radebaugh 10/16/19 07:26PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/16/19 04:28PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Graham Motzing Graham Motzing 10/16/19 04:35PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: corduroy Swoop corduroy Swoop 10/16/19 06:02PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Angry Hipster Angry Hipster 10/16/19 06:12PM
  Re: Supertech Marine....The low priced oil of Mopeds?Re: Don Ohio Don Ohio 10/17/19 02:10PM
