So I can't believe this actually looks like it's going to work. So I took a deal read block and put it on top of a stock or modified stock PA52 read block and then I put the trick metric gasket I think under that yeah and then I put the the mlm Dio intake for hobbits with the 21 phbg spigot attachment but I took the clear white spacer that comes with a 21 phbg clamp style ( off the malossi 21 phbg inline pack ) out and ground off a bit of the subframe and low and behold the carb sits exactly how I dreamed it should !! Damm!! Whoa!!! This baby ain't gonna rattle off some janky piece of radiator hose.
I've now lowered this back to oem which has to handle better. Way better.
