Hobbit 21 cc malossi phbg inline vs bringing carb out to side.
All three hobbits I am playing with have Cheetachrome modded subs and carb is inline so under frame. For clearance of the frame crushing the carb/intake the usual solution is 330 mm rear shocks. This I believe screws of the basic handling and magnifies flex issues with the subframe.
So I'm thinking about trying a new carb set up with some curved intake and a carb hanging out there.
But I've seen just how crappy the connection can be using some kind of rubber connection from intake to carb. I had this issue with my magnum that required a new intake by Nate of motomatics which transfered weight back into the motor.
I see there is a flanged new mlm with a VM 20 set up that uses actually bolts.
What nukeproof setups exist because I want to put.280 mm shocks back on to.assess the ride stability.
Post some pictures. I'm not going with any setup that "occasionally" everything falls off !!!!
Re: Hobbit 21 cc malossi phbg inline vs bringing carb out to side.
Beach Club Nick /
I have been running this setup for 3 years on my Hobbit with a 21mm PHBG and my carb only fell off once when I was first tweaking it.
Find radiator hose that'll fit snug over your intake, then hoseclamp it to the intake. Then find a short (2-4") piece of steel tubing that will fit into your carb. Clamp the carb to the steel tube, then clamp the other end of the hose clamp onto the steel tube with a hose clamp and presto you have an angled intake that lets you mess with the carb and costs like $5.
Here's the only picture I have of my bike at the moment where you can see my carb (edited)
Barry (Bob) Brown /
I used the MLM intake and a Mikuni VM20 carb to get it up and out of the subframe. It all bolt on and only Mod I need to make is to cut an inch off the end of the footrest or whatever you call them. Though Nick's way works (I have seen it) and is way cheaper. (edited)
Marc Friedman /
@ Nick I sure like your solution. What exact angled intake manifold did u use and do u recall the I'd and I'd of the metal u used to get a good seal at the phbg.
@Barry: that looks so.clean and am I right that the carb may be directly transferring weight to.the side of the subframe. That looks so freaking perfect.
Barry (Bob) Brown /
I think it weighs 1.7lbs and I didnt notice any difference from original carb location.
Beach Club Nick /
> seal at the phbg.
I didn't use an angled manifold, I used the Malossi one that comes in the 21mm phbg setup. This one: https://www.treatland.tv/honda-hobbit-malossi-PHBG-intake-p/honda-malossi-intake-0261158.htm
I don't remember the exact diameter but word on the street is 3/4" diameter with some light dremeling on the carb side works well. I used something a little too small and wrapped electrical tape twice around the tube to make up the diameter and provide a better seal.
love my dio reed adaptor and vm20. brings it up and out
idk if pedals would hit it or not... my foot pegs are mounted back by the lower shocks
(edited)
Marc Friedman /
Nick do you have any specifics on the metal pipe diameter etc that fits correctly into the intake of the carb. I want to try your method but would like specifics.
Marc Friedman /
Nick just re-read your posts and see your suggestions.
Beach Club Nick /
The best method is to just find scraps laying around, like i said I think 3/4" is the way to go. In any case you should try to make a better seal with a single layer of electrical tape or something where the carb mounts to the pipe
Marc Friedman /
<phorum break>
So I can't believe this actually looks like it's going to work. So I took a deal read block and put it on top of a stock or modified stock PA52 read block and then I put the trick metric gasket I think under that yeah and then I put the the mlm Dio intake for hobbits with the 21 phbg spigot attachment but I took the clear white spacer that comes with a 21 phbg clamp style ( off the malossi 21 phbg inline pack ) out and ground off a bit of the subframe and low and behold the carb sits exactly how I dreamed it should !! Damm!! Whoa!!! This baby ain't gonna rattle off some janky piece of radiator hose.
I've now lowered this back to oem which has to handle better. Way better.
Marc Friedman /
Dio Reed block
Beach Club Nick /
> better.
I have about 1500 miles on my hobbit with a radiator hose phbg 21 mount. The carb has never just fallen off simply because it's mounted to radiator hose.
Dirty30 Dillon /
I still strongly stand behind the '77 VM20 intake. While it wasn't perfect I was able to mod mine to use the stock airbox hole and everything.
Still suffered from having to work around frame clearance, but it was a good idea. Main reason I sold all my hobbit stock was because it seems everything performance-wise that get's built for them is a workaround, rather than a solution. The long-dong, out the side intakes are all not ideal for a hi-rpm, peaky setup where you really want that carb as close to the reeds as possible.
I really wish someone would start manufacturing rear-clutch adapter shafts for these transmissions, and remake the minarelli hori adapter shafts for vespa while you're at it.
