Puch maxi oil mix
Hi what two stroke mix do I run in my 71 n with English petrol
Re: Puch maxi oil mix
If it hasn't run in a while use 32/1 for the first tank. 50/1 from then on seems to be the norm.
Newer oil formulations are much more efficient so you can use a little less than back in the day.
Honestly I just run 40/1 in all my bikes tho.
Most use 50:1, I run 32:1, but this is in us gallons and oz, you would have to run through a converter table for Imperial measure? May also be a sticker on the tank with a ratio, there should be a little rubber cup inside the gas cap with measures on it, I think that was for mixing in the tank, but I don't do that.
1 part oil to 50 parts gas doesn't change with litres, gallons or truckloads.
Face palm, you are right....it's too late for this! My mistake!
Probably Fred /
Carpet boy83 are you a Carpet Fitter by trade?
