@ Jesse: that stator does look a bit like fort Knox. The typical moped stator has each coil more exposed. But!!!!!! It's not necessary to get into the actual coil on many light coils. One end is brought out to the to the bolt that holds the coil into the stator. The other end is the wire for the lighting. So ifbu examine the first photo all I had to do is take that exposed wire that was attached to the stator and solder a wire to it , shrink wrap it and now I have both ends of the light coil or as El pollo pointed out , the other end of all three light coils.
Your stator is probably going to be impossible to find and extract the ground ...otherwise it's a beauty.
