> el pollo Wrote:
> the frame is ground if you reassign ground to the rectifier. that is
> done by ungrounding the ac stator and running 2 phase. by changing the
> ground point and grounding the rectifier the frame now becomes 0 and the
> rectifier + terminal is 14.3vdc.
and the ac loop is floating.
which is exactly how OP described it before you came in with some cockamamie horseshit.
